Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Knee Vertical Mills
Knee Vertical Mills Discuss Knee Vertical Mills here.
Old 06-03-2009, 08:48 AM
racear*2865 is on a distinguished road
Change Speed with vfd
Have an older CNC Dynapath Delta 30 Chevalier and has adjustable speed thru belt. Have a 220 3phase in 220 3 phase out VFD. Am using a rotary converter. Want to install the VFD to auto control sppeed in program. Any help would be appreciative. Do not know where to start or finish.
thanks
racear
Old 06-03-2009, 08:56 AM
Al_The_Man's Avatar
As a general rule to integrate a VFD into a CNC controller you require a ±10vdc analogue output from the controller or at least 0-10v+ together with an output to give you direction.
Also it is preferable to be able to configure the VFD outputs for Zero speed and at-speed to input to the CNC to hold up part program control until these inputs are satisfied.
One these are in place then you would need to scale the signal, either in the CNC or the VFD or both, so that the correct S value conforms correctly.
Need Help!- I need a speed change plate for a 1986 YCM-40 supermax orizaba Want To Buy...Need help! 0 12-27-2008 09:21 AM
Pallet Change Speed 68 SS Fanuc 4 09-19-2008 09:36 AM
How in the world do you change the jog speed? CNCadmin Mach Mill 3 01-06-2007 11:42 PM
Spindle break and speed change Pneumatics is sticking Huntersyv Bridgeport and Hardinge Mills 2 01-24-2006 05:47 PM
Does controller change axis motor speed? samualt DIY-CNC Router Table Machines 5 10-10-2003 04:05 PM
