Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Knee Vertical Mills
Knee Vertical Mills Discuss Knee Vertical Mills here.
Old 07-31-2008, 04:36 PM
Stuff-Builder is on a distinguished road
Is $900 too much for a Gorton 8D mill?
Hello,
There's a Gorton 8D for sale near me for $900. The motor has been converted to a 1 hp 1 ph motor, and there's an oiling system added. The seller has a collet adaptor so that you can use tools up to 1" shank.
Is this a good deal? I'd like it for general manual machining right now. I've got a CNC Taig I use for mostly aluminum, and a 20 x 20 router for wood. So I'd like this for heavier drilling and steel work. Might CNC it after a while.
What do you think?
Scott
Gorton Tracer Mill Retrofit Fred M Vertical Mill, Lathe Project Log 7 04-24-2011 07:05 PM
Home-Brewed CNC Bench Mill Using Siex X2 Mini-Mill Head fignoggle Benchtop Machines 18 05-11-2009 11:11 PM
Gorton 3-48 Milling machine dougputt General Metal Working Machines 7 09-19-2007 08:45 PM
Gorton P1-2 + Sherline CNC mill conversion. jaydee116 Vertical Mill, Lathe Project Log 2 12-11-2004 11:10 PM
