Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Knee Vertical Mills
Knee Vertical Mills Discuss Knee Vertical Mills here.
  #181   Ban this user!
Old 05-08-2010, 05:52 AM
befega is on a distinguished road
Dear members. I'm having turkey. My machine has myte Dyna 4400. 1993 model. Battery connected to the memory parameters are sometimes garbled. Parameters have to be set. I'm done manually. I want to install from the pc parameter. I need to program and parameter information. I thank those who are interested.
Old 05-08-2010, 08:44 AM
Gold Member
Caprirs is on a distinguished road
See this thread for battery replacement and reloading parameters: http://www.cnczone.com/forums/showthread.php?t=14443
  #183   Ban this user!
Old 02-08-2011, 01:51 AM
Jonne is on a distinguished road
Thanks for CKM about nice Dynamyte info!
I like to tell my machine's (MD4400) story, this is quite unique... My machine have used 20 hours (!). Really. This machine is like new (..or if I'm presice, IT IS!).
Originally machine had buyed to machining school. I can imagine how low jaws have dropped when they figured out that Dynamyte's programming have nothing to do with standart G-code. So, machine wasn't suitable for education ( = not Fanuc... ) and it was stored.
Several years ago one of my client buy this beauty. It got more storing, because of odd control system.
Some weeks ago I bought machine and now it's waiting modernization with 99,99% Fanuc compactile controller (I import CNC-control systems and servos, so modernization is not problem).
Of cource this machine is in sale, if somebody offer me enough thick bunch of dollars... After modernization it's price is more thicker bunch of dollars, haha!!!
  #184   Ban this user!
Old 03-04-2011, 12:35 PM
Saluki Dave is on a distinguished road
Spindle and Drawbar Assy
Hi all. New guy and novice CNC user here. We have a 4400 that encountered a problem pulling the tool up on a manual change. It happened without warning after a changeover. We suspect the belleville washers, but are having some trouble with the disassembly. The manual give almost nothing, and the one dwg we got from them is indistinct. We've got it down to what appears to be a spanner nut on top of the spindle. Has anyone done a changeout like this? Any docs/photos/advice?
All will be appreciated.
Thx
Dave
Old 03-04-2011, 04:11 PM
Gold Member
Dave,
There are specific tools (surprise!) for getting the draw bar apart. Check this thread for the tool info. Specifically, look at posts #7 and #13 for details of the washers and tool to disassemble the draw bar.
  #186   Ban this user!
Old 03-21-2011, 03:46 PM
Here is couple images about that machine. Enjoy.
  #187   Ban this user!
Old 03-22-2011, 07:09 AM
Thx
Dave
Thanks to some help from the board I got this fixed. It was actually a pretty simple procedure once I understood the hardware. Interesting symptoms so I'll pass along the story.
The machine is cutting very light grooves in the XY plane. We'd had no issues with accuracy or function. I took it down to do a changeover, and when I tried to clamp the tool afterwards, it wouldn't pull up completely. I couldn't believe it was the bellevilles, as it had been functioning perfectly an hour before. It was the bellevilles. About half were dead flat, and most of the remaining were significantly deformed (<.055 vs ~.062 spec). Quite a few were fused together in stacks of 2 to 4. Replaced the washers, reassembled, and no problem. I also managed to drop the drawbar and lose the locking balls, but the replacements came directly from McMaster (interestingly they were 3/16; most if not all of the machine is metric).
  #188   Ban this user!
Old 04-12-2011, 12:53 AM
JoseGarrido is on a distinguished road
Originally Posted by LYN BYRD View Post
I am retrofitting a DM4400, so I will be parting out the control, axis drives, and related hardware. If anyone is interested in these items, let me know.
Hello
I´m new in this forum,
Do you have the steppers boards? I have a problem with the X stepper Board on my DM4000, its a 4X00 DM Rev5.
  #189   Ban this user!
Old 04-12-2011, 06:09 AM
LYN BYRD is on a distinguished road
Yes,
I have all of the boards for the control.
  #190   Ban this user!
Old 01-30-2012, 10:42 AM
CNC Bill is on a distinguished road
Servo Dynamics SD 3060 drive
I have a question about connections to the servo dynamics sd1 3060 drive. My 4400 has been retrofited with a CNC4PC C6 spindle card CNC4PC . I was told that it worked until the gnd and 0-10v connections were accidently disconnected, and now no one remembers where they go. I'm thinking the j1 jummpers gnd and +15v.(Edit: signal, aux, tach?) I found the pdf manual at warp9 site.
Also there are 3 (could be 4 as someone has messed with the connection) wires in 1 bundle comming from spindle connections A1 and A2.(Edit: T1, T2, could that be tach?) What do they do and do they have to be connected?
I'm having trouble because so many items have been changed or removed.
Any help is greatly appreciated, Bill
P.S. I got E sized electrial drawings with the machine. I was thinking of posting 4 to 6 pics, so they coud be printed out. Let me know if anyone is interested.
Last edited by CNC Bill; 01-30-2012 at 12:35 PM. Reason: It was a LATE night, and it was dark out! And thats my story...
  #191   Ban this user!
Old 02-18-2012, 12:42 AM
chaparro is on a distinguished road
there is some ideas
revisa los siguientes puntos
1.- el voltaje de alimentacion de la maquina.
2.- revisa que no tengas caida o semiaterrizada una fase.
3.- revisa los capacitores posiblemente uno este dañado
4.- Revisa individualmente los diodos es muy probable que uno este dañado
5.- Revisa los contactos de los contactores principales posiblemente una fase no este haciendo contacto correctamente.
animo solo es cuestion de tener paciencia.
Originally Posted by ckm View Post
Well, I had been hoping to post that my Servo Dynamics SD-3030 spindle drive was fixed, but it's not quite yet. I repaired a bunch of burned out wiring in the power supply. It turns out that the OEM put wire ties every 1/2 inch on all the wires. Great, but over what I guess are power resistors, the ties were so tight that when the wire insulation got brittle due to the heat, the ties just wore through.
The net effect of this was that the fan stopped working, causing further wiring failure. I replaced everything with automotive grade wiring, which solved some of the spindle problems (e.g. now the spindle turns on initialization). However, I was still having an error during initialization. The spindle would spin up, then the drive would error out with an over-voltage error. Careful examination of the 6 rectifier diodes revealed one with clear burn marks. It was replaced.
I thought this would be the end of it, but the drive still errors out at initialization with the same behavior (spins up for 10 seconds, then errors with overvoltage). Resetting the drive produces a large buzzing sound from what appears to be the power supply. I suspect that more of the rectifier diodes are bad, but am not sure. The DC drive voltage reads 80v and I haven't had time to check the bus voltage coming from the power supply yet.
The manual stats that the error led is as follows:
Code:
Voltage - This LED will give an indication for these conditions:
1) Bus voltage has exceeded 195 VDC, this condition can exist if:
    a) The shunt regulator fuses are blown
    b) A regulator is required to handle regenerative motor
        energy, while decelerating, due to excessively high
        inertia.
2) The sum of the +/- 15 Volt Bias supply is less than 28 Volts
    DC.  This condition can exist if a line transient causes
    the bias supply to dip momentarily or the bias supply has
    failed.  Check bias supply fuse.
I checked the shut regulator fuses, and they are OK, and there is a regulator. Also, since the noise on reset exists at dead stop, it would seem that the problem is elsewhere.... I also checked the bias supply fuse and the voltage sum. Both seem OK.
The power supply seems pretty simple. It's basically six rectifier diodes that rectify the incoming 3-phase AC into DC, then pass it to a large filter capacitor. There is also circuitry for shunt regulator which feeds three large resistors. I don't know enough about power drives to understand the whole thing, but it seems that the only two places that could generate overvoltage would be either the cap or the rectifier diodes. I suppose the switching MOSFETs on the shunt regulator could also be bad, but this would not explain the buzzing on reset.... Or it could be wired to the wrong ends on the transformer (hmmm, should check that first...). My next step is to test the power supply more thoroughly, starting with the rest of the diodes and the capacitor.
The other possibility is the power output stage of the amp, which is a bunch of MOSFETs driven in PWM fashion at 2Khz. One interesting thing was that when I disconnected the control and tach inputs, then started the machine, the drive went into run-away mode, something I did not expect. I thought that enable and signal were necessary at least for the thing to run. This may or may not indicate a problem with the amp itself. I'm going to take the heatsink off the MOSFETs to see if I can divine anything from their looks...
Regardless, I've been trolling ebay and the 'net to find a reasonably cheap replacement. If anyone knows of a 150-180v 6HP (~30-40A) DC motor controller with integrated power supply for a reasonable price, please tell me. I do have an AMC controller of the right size coming, but no power supply... In the meantime, I'm continuing to troubleshoot the amp as best I can. I have an o-scope and various other electronics testing tools, as well as the manual for the amp, but I don't know an enormous amount about these things, so it's slow going.
In other news, I designed and had made some breakout boards to convert the existing control system to Mach3. They arrived today. I now have most everything I need for a conversion, so I'm going to start on that next week.
If anyone has ever worked on a Servo Dynamics drive and has some pointers, I'd be grateful if you'd be willing to share your wisdom.
Thx.
Chris.
Tags
4400, dm4400, dyna, dynamite, mechantronics
Dyna 4400 pst help JWWalthall Post Processors for MC 4 12-15-2010 05:38 AM
Dyna Myte 4400 (or other model) owners/users mmedina General Metal Working Machines 49 04-01-2010 10:22 AM
Dyna mechtronics DM3000 Raskins General CNC (Mill and Lathe) Control Software (NC) 13 05-06-2008 06:26 PM
Dyna Mechtronics 4400 Professorwiz Machine Problems, Solutions , Wireless DNC, serial port 4 05-19-2006 02:52 PM
DNC on the Dyna Mechtronics Professorwiz Machine Problems, Solutions , Wireless DNC, serial port 2 08-11-2005 11:49 AM
