| Knee Vertical Mills Discuss Knee Vertical Mills here. |
Greetings, Is there any way to adjust parallelism of the table? I have a BP clone, Lagun by name, and just discovered the table is way out of parallel along both the X & Y axis. I have a dial gauge in the chuck with the tip on the table. When I move the table along X or Y the gauge moves showing the table in not parallel to the spindle. Is there any hope? Thanks, Kerry |
| Not to insult you but mMake sure you're not reading an out-of-square/mismachined tablle "side" or slot... All that being OK. you just might have to dust off the slots to square them up with/to the spindle. Might have to make/use oversized "T" nuts but at least it would salvage the mill. |
| Do you have the indicator on the table surface or against a vertical surface ( T-slot/side of table) ? If you have the indicator against the top surface of the table, then I'm not suprised, the table on knee mills tend to "tip" when moved to the extent of their travel i'd say up to .005" on a well used machine, adjusting the gibs may help. |
| Gibb adjustment help | TT350 | Tormach PCNC | 11 | 11-15-2007 09:04 AM |
| QC Nut adjustment | zcases | Bridgeport and Hardinge Mills | 3 | 06-10-2007 10:10 PM |
| how can i measure parallelism of 2 linear slide? | cnc2k | General Metalwork Discussion | 1 | 03-13-2005 10:26 AM |
| Slide adjustment? | freezer | DIY-CNC Router Table Machines | 0 | 02-21-2004 11:17 AM |
