Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Knee Vertical Mills
Knee Vertical Mills Discuss Knee Vertical Mills here.
  #217   Ban this user!
Old 08-21-2010, 03:40 AM
macrylinda1 is on a distinguished road
Originally Posted by Sandiapaul View Post
Can anyone provide details of how they coupled up to the screws? How did you retain the adjustment for the thrust bearings and add a coupling?
I was thinking of just machining a coupling to go over the shaft collar and keeping the orig. setup in place, but that seems a little hokey.
Thanks,
Paul
Matt
If you're a one man shop, you physically can't handle more than about 3 machines unless you're running bar feed lathe jobs.
I have 2 Dyna-Mite 2400's and it can be tuff to keep up with them.
___________________
watch free movies online
  #218   Ban this user!
Old 08-21-2010, 03:42 AM
Hey the pics are back! Thanks!
Soon I will bug all of you with my questions on a Dyna conversion I'm about ti start!
  #219   Ban this user!
Old 09-08-2010, 08:00 PM
Alex_Cole's Avatar
Alex_Cole is on a distinguished road
I have not posted in a while and I am sorry for that. I recently moved my family to Florida and have been busy. My machine tools are currently in storage but planning on getting them down here in about two weeks or so. Once it arrives I will try to get some pictures of the couplers up for you. I currently have the mill broken down for storage and transport.
Alex
AC
Has anyone seen my pillow?
  #220   Ban this user!
Old 09-10-2010, 07:34 AM
Fastest1 is on a distinguished road
Alex, Why did you replace the limit switches in the DM 2400? I pulled mine apart to verify they were clean and just to have a known starting point on my maintenance. I was shocked to discover all parts were gold plated internally. Running Mach and having 1 switch per axis would allow accurate homing the way I see it. Just seems like very quality switches to be eliminated. Good luck with the move.
  #221   Ban this user!
Old 09-18-2010, 01:57 PM
Alex_Cole's Avatar
I am going to replace the switches because the ones that are on the machine run in a Normal Open configuration. That means the 5v only makes contact if the contacts touch.
I want to run mine in a Normal Closed config. That way if a wire breaks or becomes compromised then the loop will be broken and stop the machine.
My tools should be arriving today so I will have lots of work to do putting it all back together as I broke it down to keep the components safe for the move.
AC
AC
  #222   Ban this user!
Old 09-28-2010, 09:02 PM
Alex_Cole's Avatar
Well I got the machines moved into there new locations and have even made some parts. The mill and lathe both seem to have made the move ok.
I really need to get a coolant pump setup for the mill now as babysitting the machine while cutting aluminum is getting old.
Any ideas?
AC
AC
  #223   Ban this user!
Old 09-28-2010, 09:35 PM
Gausswave is on a distinguished road
Build a big tank and fill the whole mess with a dielectric lubicant and submerge the whole mill! Radical ideas.... I got plenty On a more practicle note I've been pretty happy with my cool mist setup on my large mill.
  #224   Ban this user!
Old 09-15-2011, 12:20 AM
kel1 is on a distinguished road
Wow ! ! !
While your at it you could convert it to a Mill/Sinker EDM System. (Really Radical !)
What do you think Alex?
Sorry I haven't posted for so long but I have just been so busy. My Mill is working fine. I blew 1 axis on my Xylotex board so I had to find the bad chip and remove it so I can use it as a 3 axis board. The Xylotex boards wont work unless the bad chip is removed. Other than that the Machine works great. I installed dampers that I designed on my Steppers and that increased all of my axis speeds dramatically. I also made an enclosure for the Machine and installed a Coolant Mist System and a vacuum mount.(Note: I have no static issues with the vac.)
I still want to install the fourth axis at some point.
Thats about it for now.
Cheers all !!!
Dyna Mechtronics cnc Knee Mill need help with control wisp Knee Vertical Mills 9 08-25-2011 03:35 AM
Dyna Myte 2000 mill BCat Benchtop Machines 9 09-30-2009 02:44 PM
Help with DYNA 2400 setup to Bobcad adaptforge BobCad-Cam 2 07-10-2007 05:47 AM
Connecting FlashCut SG to Dyna 2400 erazz General Electronics Discussion 1 06-13-2007 02:18 PM
DIALup Demo dk1machine OneCNC 4 01-18-2005 10:23 PM
