Results 1 to 8 of 8
Thread: Vertical Mills
    Registered charper's Avatar
    Oct 2006
    Vertical Mills
    Can someone please take a few minutes and explain some basics of what a vertical mill is and what it is used for?
    "Craft is What I do All Day. Art is what I have at the end of it" Jean Weller
    Gold Member widgitmaster's Avatar
    Jun 2005
    simply put, the cutter is vertical as apposed to a horizontal mill!
    The most popular vertical mill in history is the "Bridgeport", and is aclaimed to be the only machine capable of reproducing itself! Or should I say that it can (with a good machinist) make every part of itself one piece at a time!
    It's also called a Universal Mill, and a Knee Mill!
    Hope this helps!
    Eric
    Feb 2006
    us
    Here READ this! http://www.americanmachinetools.com/...ng_machine.htm
    How to use a Milling Machine
    Oct 2005
    cairo
    Drill TO Cnc drill
    hi
    i would like to develop aan ordinary Drill to a CNC Drill if anyone have some documents or help please it will be great and thanks
    May 2007
    I need some help to fix my vertical knee mill with allen bradly controler.
    when I power it up it come out a message (pc inhibiting start) if any one have any answer will be great and thanksfull.
    Dec 2010
    well what cant u do with a mill???
    Dec 2004
    Quote Originally Posted by ehickman View Post
    It's not so much what you can't do because almost anything can be achieved, given the right tooling for a mill. The limitations are a matter of what degree of accuracy can be achieved. A BP style knee mills is considered a graduated drill press for close tolerance work. They're fine for work that's +/- .0015 and location is a function of wear on the leadscrew or the limitation of the DRO and it's accuracy. There are good reasons for using a lathe, grinder, EDM, or jig bore instead of a mill. A mill is versatile but it's a matter of how well they'll do a given job.
    Mar 2010
    A Mill is
    Quote Originally Posted by roninB4 View Post
    Out of interest a Milling machine is completely different to a Lathe. But some machining functions are common to each machine. Both can Drill, Ream Bore, face to name but a few. But neither a lathe nor a Mill (at least not the type of mill described here) can cylindrical or surface grind. And it is an impossible function to do EDM (modern EDM processes Wire or Ram) on a lathe or mill. A Jig Boring machine (traditional Jig Borer) too is a completely different design (provides a different set of functional methods) of machine to a Knee Mill. In some ways a BP type mill IS a very versatile machine, but to say you could use an EDM (wire or Ram types), Grinder, lathe, Jig Borer INSTEAD of a mill is silly (understatement). And to say that a BP style Knee mill is a graduated drill press is just as (see previous sentence).
  • Posting Permissions
