| Knee Vertical Mills Discuss Knee Vertical Mills here. |
#14
| hi smarbaga , sorry ,just saw you post the Fty website link at here: http://www.zjxltz.com/english/about.asp detail of ZX7045 of this Fty is: Model ZX7045 Max. Drilling capacity(mm) 45 Width of face milling(mm) 80 Diameter of vertical milling(mm) 28 Spindle travel(mm) 120 Distance spindle axis to column surface(mm) 260 Max. Distance spindle nose to worktable(mm) 475 Spindle taper MT4 Spindle speeds range(r/min) 95~1600 Spindle speeds series 6 Dimension of worktable surface(mm) 820Χ240 or 730Χ210 Table travel(mm) 550Χ200 or 500Χ175 Overall height(mm) 1050 Motor(W) 750 or1100 G.W./N.W.(Kg) 318/278 Packing dimension(cm) 87Χ75Χ112 97Χ75Χ112 |
#17
| http://www.westlakemachine.com/product-DandM(eng).htm ZX7045Max. dilling capacity 45mm Width of face milling 80mm Diameter of vertical milling 28mm Spindle travel 120mm Distance spindle axis to column surface 260mm Max. Distance spindle nose to worktable 475mm Spindle taper MT.4 Spindle speeds rang 95-1600rpm Spindle speeds 6 Dimension of worktable surface 820Χ240mm Travel of worktable 550Χ190mm Overall height 1050mm Motor 750 or 1100 W G.W/N.W 335/270kg Ship measurement 78Χ88Χ115cm |
