Hey every1 super new to this stuff but not new to running CNC's . I have a couple omniturns and I have always wanted a mill. I found a deal that was hard to pass up so I got one. I have just aquired a Kasuga mill with a bandit control and QuickDraw tool changer. The bandit has got to go. I tried to power it up but no dice. The control turns on but no "bright light" display. A few LEDs light up inside the control and the fan turns on. If I hit the breaker in the back the reset light turns on and the reload light also.
It has 3 summit dana DC servo motors 90V 74A 1430RPM. I couldn't get the spindle to start maybe I'm doing something wrong. I need to break out the volt meter and test the wires to the motor. Someone at the machine dealer pinched and most likely severed the cable with a forklift.
Anyhow I want to run a new control on here w/ Mach 3. I have no clue where to start any and all help is much appreciated. I was going to try and test the servo motors but I can't get the control to do anything.
Are my servo motors good enough for what I plan to do. I want to have an expandable setup and run a 4th axis on it. I have a old HAAS SRT laying around and I was wondering if I got the plug for it and wired it into my control would Mach 3 run it?
