Originally Posted by
Deano7/11
for me the mach3 thing is more the fact that i seem to read about alot of bugs etc with the program. the more i read the more it turns me off in a way.
learing a new process doesn't scare me but relying on a program that i am not convinced is that great does concern me. i have downloaded the program and had a play but i struggle with it. if / when i take the plunge i will be forced to understand it more and my perception of it will most likely change. i would be wanting the utilise the importing of g code from solidcam or similiar more 80% of the work i would want to do, but then again as i get more familiar with the program i may not need to do this.
how did you go adjusting the ball screws to zero backlash. how did you sort out the ball screw mounts under the table?
