Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Knee Vertical Mills
Knee Vertical Mills Discuss Knee Vertical Mills here.
Old 04-16-2011, 09:32 AM
Jackal66 is on a distinguished road
Retrofit on Hurco KM3P
Well the retro has started. The wires are being cut now.
No turning back.
I will post progress on here as it goes.
If you need any Hurco parts let me know.This machine has a bx control.
It has this board from amts that lets you change the masters and drip feed g-code from a computer:
ACCURATE MACHINE TOOL SVC
Also there is a CMC systems tape emulator board, too.
I am selling everything cheap. Just ask or make offer.
Pics will come soon.
JAckal
Everything is bio-degradable, if you run over it enough times with the lawnmower.
Old 04-16-2011, 07:21 PM
skullworks is on a distinguished road
Cool
You didn't state what you were refitting to.
Do you intend to continue using the Voltec card to control the speed adjusting motor which sets the vari-drive pulley positions for the programmed spindle speed?
Are you going to reuse the existing servo amps?
Just wondering what your end target is.
Old 04-16-2011, 09:01 PM
The servo drives will be Dugong, with Mach3 & CNC4PC boards. The parts have been back-ordered and should be in next week.
Probably for the spindle, a VFD will drive it. Starting out I may just use the fwd/rev contactors & adjust the speed manually.
There should be some pics in a few days.
JAckal
Old 04-19-2011, 09:13 PM
Here are some pics of my butchering:
Empty cabinet
Name:	Hurco cabinet gutted.JPG
Guts removed carefully didn't pull or rip out any of it.
No turning back now!!!!
Looking inside the cabinet, the back plate or whatever it is called, come out rather easy after it is cleaned out.
This will make for a neat & tidy installation for the amps, etc.
Right now it isn't impressive at all. This is just proof that it is started. If I don't post pics as it goes, it will pile up and never get posted.
Stay tuner for more havoc.
JAckal
Old 05-06-2011, 02:42 PM
I've started putting the mother board & PC stuff in the cabinet on the mill.
The computer was completely dismantled and just some of the frame/skeleton, was put in the cabinet to mount the motherboard, power supply, CD drive, hard drives, & fans.
After installing, the computer was booted up with a monitor, mouse, and keyboard connected to make sure I didn't fry anything.
When the cable connectors & bulkhead are in place for exiting the cabinet, there will be more pics.
It's easier for me to post a little at a time, than to let the pics and info pile up.
If it piles up, it may never get put on here.
Name:	PC mounted 1.JPG
Name:	PC mounted 2.JPG
Here is a swing out plate that Hurco had some of the factory power supply & relays mounted to. None of this was thrown away. The servo drives will be mounted to this plate. Since it is mounted with hinges, a ground wire will connect it to the large ground junction in the bottom of the cabinet. The doors and main casting of the machine go to this ground point. The plate will get cleaned off with sandpaper before the drives are mounted with a heat transfer paste. Hopefully this will gain a little more room and make things somewhat easier to work with.
Name:	Swing out drive plate 1.JPG
Name:	Swing out drive plate 2 .JPG
Name:	swing out drive plate 3 .JPG
Here is a small bracket that I made for using the factory power switch & LEDs from the PC.
This may get changed later.
Name:	switch  and light bracket.JPG
There will be more as things progress.
Hope all of you like this.
JAckal
Old 05-10-2011, 07:48 PM
Here is some more info from some other threads here on CNCzone concerning this build.
http://www.cnczone.com/forums/gecko_...ive_these.html
http://www.cnczone.com/forums/gecko_...ard_g320x.html
http://www.cnczone.com/forums/genera..._windings.html
Al was a tremendous help on this.
Have any of you noticed the buy me a beer emblem in the upper right corner of someones profile? It is right under the location, join-date, number of posts, etc.
PIC:
We need to start buying these guys a beer for all they help they give.
It is only $5 thru Paypal.
They don't get paid for helping us, and it is worth a lot more than a beer for fixing a machine.
Just something to think about.
JAckal
Old 07-08-2011, 06:51 PM
mtechserv is on a distinguished road
Hey JAckal,
Any progress on your project?
I would like to follow your retrofit closely, as I'm considering doing a similar project.
mtechserv
Old 07-08-2011, 09:18 PM
mtech,
There are quiet a few some pics that I can load up. All info has been saved.
Each wire has been numbered on both ends to help identify.
No one has really shown any interest ,so I haven't posted anything.
Stay tuned for more info, then.
What kind of machine do you have?
Have you decided on any parts & components, yet?
JAckal
Old 07-09-2011, 12:24 PM
adee1066 is on a distinguished road
hey JAckal,i like what you are doing.very interesting.i'm thinking that this may be the way to go with my machine sometime.
keep the pics and posts going.
all the best,adee.
Old 07-09-2011, 03:37 PM
Cool
Just cause we are not asking questions does not mean anyone has lost interest.
I have a KM3P with the MAX32 upgrade with all the bell & whistle software options, so as long as I can keep it working as OEM I will.
On the other hand I am looking for a 2nd KM3 or KM3P which the CPU part of the control has made its final trip south so to speak but the servos and amps are still functional. I want to gut the control computer and spindle controls and convert it to EMC2 with a VFD spindle drive with encoder for rigid tapping and also a 4th axis which is just too much to consider adding to the OEM config.
Another option I am considering is using a monster stepper to drive the knee with glass scale feedback for in position checking. This allows the tooling to be outside the quills 5 inch travel limit. The "W" axis would not be used while in most programs except for when a hole would need to be drilled deeper than 5". Generally it would only move the knee for tool changes.
Based on the other machines I've used EMC2 on I expect the EMC2 converted machine to run circles around the OEM controlled machine in a production mode - but for quick single part jobs I can have the machine cutting using the Ultimax conversational before I would be ready to post G-code.
Likewise having 2 machines with common tooling is also a plus. I have a very nice U200 tooling package I've built up.
  #11   Ban this user!
Old 07-10-2011, 06:54 AM
Jackal,
I would be very interested in seeing the other pics that you have. I have a Clausing Kondia CNC knee mill from the early 90's that is very similar to your Hurco. It has the rigid head, mounted on a ram.
It currently has a Dynapath Delta 20 on it. I've owned it for about 6 years. The controller has been getting flaky for the past couple years. So I'm beginning to look into retrofits.
I'm leaning more towards EMC instead of Mach right now, but haven't definetely decided just yet.
mtechserv
  #12   Ban this user!
Old 07-10-2011, 09:46 AM
Thanks Guys,
I'll get some pics up.
Mtech,
If you need any parts to limp your machine along let me know and I may have something that will give you a little time before your retrofit.
Skull,
Mine had the bx control, but some of the amps ,etc. may work on yours if you need any parts.
In a few day you will see some more pics.
JAckal
Retrofit advice on Hurco km3P Jackal66 HURCO 7 10-26-2010 08:58 PM
Hurco KM3P won't zero home in x axis Jackal66 HURCO 6 05-29-2010 09:09 AM
Need MasterCam post for a Hurco KM3P oem3dcut Post Processor Files 2 03-18-2010 09:05 AM
Need Help!- Hurco KM3P ivanfed HURCO 0 04-20-2009 04:48 AM
Hurco KM3P HELP winds1sj HURCO 7 12-20-2008 01:44 PM
