Results 1 to 3 of 3
Thread: Is anyone using a Proto Trax MX2 with CAM software?
    Registered SolidCAM_13's Avatar
    Jun 2010
    Does anyone know if you can transfer a CAM generated program via RS 232 into a retrofitted mill with a ProtoTrax MX2 controller?
    Cheers
    D
    Mar 2010
    I am helping a company that has a Proto Tarx, we have been using CamBam and just transfering with a memory stick, There are som eissue that we are still sorting with the software but the mill is a lot more usefull.
    Tony
    Aug 2008
    Prototrak MX2 and RS232
    of course you can transfer programs from a computer to a Prototrak MX2 by using rs232 null modem serial cable.
    .......i would recommend reading the manual. many Prototraks have a separate CadCam interface manual. the MX2 is a 2 axis machine so Fanac 6m code or Prototrak SWI code it can read. if you upload 3 axis Fanac gcode it will usually have problems translating Z axis commands and you will have to manually edit them.
  1. Proto-M byggetråd
    By mcentric in forum Norwegian Club House
    Last Post: 03-04-2010, 11:52 AM
  2. TRAX TRL 1840SX
    By nitrain in forum General Metalwork Discussion
    Last Post: 04-14-2009, 09:51 AM
  3. proto trax mx2
    By johnalu in forum Europe Club House
    Last Post: 11-27-2008, 10:00 PM
  4. RFQ 2 Op CNC Milling (Proto)
    By Spike_TDI in forum Employment Opportunity
    Last Post: 04-27-2005, 07:36 PM
