Page 2 of 2 FirstFirst 12
Results 13 to 15 of 15
Thread: BRINGING CHARLEY BACK TO LIFE
  1. #13
    Dec 2003
    40 lbs.
    It is fail safe, no air - brake is off.
    Jul 2004
    Thanks Al,
    I'm busy trying to turn my rats nest wiring of the homemade rotary converter to respectable looking setup.
    Since I got the machine I've been trying to learn all I can by looking and thinking ,;-) since I can find no manuals. This is the first time I've even seen a full size mill.
    When I look at the knee travel, and the tables proximity to the quill, it seems that the table will hit the tool holder long before the knee runs out of travel. That makes me think there might have been a riser under the ram, at some time in the past.
    Can you tell me what the attachment of the ram base to the main casting looks like?
    There are four stout bolts that appear to hold it in place. I stuck my camera inside the base casting and took the picture below. What do those six bolts do?
    What I'm really trying to figure is what I'd need to do to construct a riser.
    The diameter of the ram base is 15". If I found a 15" diameter riser from another machine, what kind of work might I need to do to it?
    Thanks for any and all info,
    Ozzie
    Attached Thumbnails Attached Thumbnails BRINGING CHARLEY BACK TO LIFE-p2220337.jpg   BRINGING CHARLEY BACK TO LIFE-p2220339.jpg
  3. #15
    Jul 2004
    Ram attachment
    I've been looking at some online manuals of other mills, parts sheets, and I guess those screws hold the plate that they go through and into the bottom of the ram base.
    I'm thinking there would be no reason for this arrangement if the ram didn't swivel! If my ram swivels, it must be stuck because two of us couldn't move it. That would also mean that the four big bolts heads ride in a circular groove in the ram base?
    Can anyone confirm that construction?
    Thanks,
    Ozzie
  1. Bringing the Art of Scraping into the 21st Century?
    By Oldmanandhistoy in forum Linear and Rotary Motion
    Last Post: 12-23-2009, 02:32 PM
  2. Need Help!- Required height for bringing in a Mazak VTC-41
    By Jcip in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-13-2008, 07:59 AM
  3. bringing chinese lathe across border
    By ged in forum Mini Lathe
    Last Post: 07-29-2008, 11:35 AM
  4. Bringing on the power
    By fatal-exception in forum Gecko Drives
    Last Post: 03-21-2008, 09:17 PM
  5. Bringing objects together in V19 & general questions
    By rustyolddo in forum BobCad-Cam
    Last Post: 07-31-2004, 10:14 AM
