Results 1 to 4 of 4
Thread: Enshu Yuasa AccuMill 1547 with Fanuc 3M
    Jan 2011
    I keep getting a Z overtravel alarm. While attempting a reference return it will go above zero and trip out on a servo reading before hitting the overtravel limit switch..
    How do you calibrate this axis?
    Nov 2009
    Please check the limit switch, its resistance should change as the dog moves its arm past the contact point...
    Jan 2011
    Which limit switch? I have a upper a lower and a slowdown on the left side.
    Nov 2009
    Well, since the Z axis is probably over travelling going in the up (Z+) direction, I would check all of the limit swithces that it is hitting going up (in direction of the alarm) first.
  1. NEED ADVICE re: Enshu Yuasa AccuMill 1547 with Fanuc 3M
    By crobox in forum Knee Vertical Mills
    Last Post: 01-10-2011, 12:39 PM
  2. Need Help With Enshu , schematic , 6m Fanuc
    By Rob Lacy in forum Forum Questions or Problems
    Last Post: 08-17-2009, 05:11 PM
  3. enshu yuasa accu-mill am1547 tool offsets?
    By kustomkb in forum General Metal Working Machines
    Last Post: 06-05-2009, 11:51 AM
  4. Enclosure for a Enshu AccuMill
    By AccuMillGuy in forum Knee Vertical Mills
    Last Post: 03-29-2009, 01:39 PM
  5. Need Help!- Troubles with YUASA ACCU-MILL AM 1547
    By thucmie in forum General Metal Working Machines
    Last Post: 09-09-2008, 03:37 AM
