| Knee Vertical Mills Discuss Knee Vertical Mills here. |
About a year ago, I built myself a quill drive, using a mounting method I've never seen anyone else use - it's simple, robust, and leaves the tramming bolts totally accessible. The entire drive mounts to a plate clamped between the two halved of the mill head, with the lower end supported by a single bolt through the boss at the bottom of the old quill stop screw. It works very well, is very accurate, and I've since made a couple more for friends, who are equally happy with the result. The picture was taken before I'd made the covers to enclose the belt and ballscrew. The whole thing is now fully enclosed. Here's the original build thread from last year: New Quill Drive Design Regards, Ray L. Last edited by HimyKabibble; 12-19-2010 at 12:19 PM. |
| Hi Ray, It came up well, I have one question did you remove the existing bracket that is bolted to the quill and replace it with your own. If so is the replacement one steel or aluminum? I have heard that on some machines the bolt off that goes into the the quill comes lose as it not that strong. Have you heard of any problems? Tony |
I made a new yoke, from 1080. That is the weakest part of any quill drive that attaches to the quill in that manner (which, AFAIK, is ALL of them... There's really nothing else you CAN attach to.). I made the yoke fairly "tall", so it contacts the quill surface both above and below the bolt, so prevent the yoke from "tilting" relative to the quill under heavy loads (mostly if the quill is jammed, due to hitting a stop or the tool being driven into the table/workpiece). But, it has not been a problem on mine. The quill is pretty thick in that area, so I think it would take some serious abuse to loosen things. Regards, Ray L. |
| Hi Ray, Thats a good suggestion, I am limited on the top travel as I have a air tool changer so need to go to the top fully. Later I think I will change the attachment to the quill as well. I also noted that you went for coming down from the top with the support as opposed to me who used the 4 front bolts. It is good to see different ways of doing the same thing. Its interesting you put a lower bearing on the ball screw. On the commerical Prototrak units they just have the one at the top. Have a great day Tony |
I did start designing one that mounted to the tramming bolts, but after reading the alignment instructions for commercial units done that way, decided it would be a lot of hassle, if/when I needed to tram, or tlit the head. I could've put another bearing above the pulley, but it seems easier, and stronger, to put it on the bottom. Functionally, I'm sure it doesn't matter, as long as everything is properly aligned. BTW - I do have an unused commercial quill drive, if anyone wants to buy rather than build. It has a lovely HiWin ground ballscrew, and name-brand Japanese A/C bearings. It will accept pretty much any NEMA34 or 42 motor. PM me if interested. Regards, Ray L. |
| They're standard BP dimensions - 3.85"/97.8mm vertical spacing, 4.6"/116.8mm horizontal spacing. The holes are over-size, to account for machine variation, and to allow perfect alignment of the whole assembly parallel to the quill. Regards, Ray L. |
| Looks like I need to change that bracket from the ball screw nut to the quill. I think my one is not strong enough so I will do it like yours. I measured the movement in my current bracket last night and it was about 0.3mm of movment. It was all in the plate being to small. Tony |
Regards, Ray L. |
#12
| On the X & Y that I have you find that if you jam say a vice into the back of the mill (did that last night) the motor stalls and no damages is done. Tony |
| New Quill Drive Design | HimyKabibble | Bridgeport and Hardinge Mills | 60 | 01-27-2012 04:52 AM |
| Anyone Need A J-Head Quill Drive? | HimyKabibble | Bridgeport and Hardinge Mills | 0 | 06-07-2010 12:08 AM |
| Quill design and materials | semi-lucid | Mechanical Calculations/Engineering Design | 5 | 03-16-2009 07:27 PM |
| Quill Drive Reduction | HimyKabibble | Bridgeport and Hardinge Mills | 5 | 02-10-2009 11:54 PM |
| Help with BP J-head CNC quill drive | titchener | Bridgeport and Hardinge Mills | 7 | 12-28-2008 05:16 PM |
