Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Knee Vertical Mills
Knee Vertical Mills Discuss Knee Vertical Mills here.
Old 07-07-2010, 02:10 PM
Southbend Sam is on a distinguished road
2 Axis Anilam Retrofit
I am considering buying a Bridgeport with a 2 axis Anilam 1100 CNC control. The Z axis is manual but has a DRO which reads out on the CNC display. I would like to retrofit to Mach 3 and replace the old electronics. Replacing the X and Y axis systems seems straightforward, but the Z is giving me some problems. First, how do you get the part program to pause when a Z command appears (like the Anilam does) without manually rewriting all Z commands? Is it possible to connect the Z axis scale to the Mach control and have it read out on the Mach screen?
New Machine Build- EMC2 Fallowing errors, Supermax/Anilam retrofit jvanatta LinuxCNC (formerly EMC2) 9 10-13-2009 12:18 PM
Need Help!- camsoft retrofit to a anilam crusader retrofit bowlingmac CamSoft Products 44 07-24-2008 09:00 PM
Time to retrofit-Anilam Crusader GXM seems to be on it's last legs... zoeper Bridgeport and Hardinge Mills 3 06-24-2008 08:24 PM
Retrofit Anilam Control buff324 Controller & Computer Solutions 3 04-29-2008 06:22 AM
Weight of BP Series 1 W/ Anilam Retrofit ? CNC OT Bridgeport and Hardinge Mills 1 02-16-2007 08:13 PM
