| Knee Vertical Mills Discuss Knee Vertical Mills here. |
#37
| Problem solved (well, fingers crossed anyhow!) There seemed to be some noise due to the use of the err/res detection circuit. So unplugging the wires from the gecko's to this circuit cured the problem. I just hope thee are no more issues when I start the motor!
#38
| There may be some that still remember this thread, so I thought I'd give an update: I'm the new owner of this project. Since getting the machine, I have: Gutted and rewired the control box. Modified the Z-axis ball nut housing with more heavy duty grub screws. Found the source of the 'noise' The 'Noise' The noise was nothing to do with the control box as I initially suspected. I had rewired it, paying attention to good practices to reduce crosstalk and capacitive coupling. The 'noise' was still present. It turns out it was a far more simple problem. The Z-axis motor employs some sort of diode configuration to ensure its correct operation. There was a ground lead to this, crucial to its correct operation and this ground lead was connected to the chassis of the Mill. HMM! I thought. The chassis of the Mill was actually floating with respect to earth. So... to my eternal relief, I simply reattached the wire to Mains Earth... and the machine works perfectly. Let this be a lesson to you all to ground properly ![]() Comments appreciated. Macaba |
#39
| I need some help. I am thinking of counter-balancing the weight of the quill with a cable and pulley system (simplicity wanted!), and I would like some good suggestions as to what the likely weight of the quill of this zenith knee mill is. All I can guess is HEAVY! Once I have an idea of the weight, I can then look at cable guage, pulley sizes and what it is going to be supported by. Thanks for any help you can give |
| cnc mill retrofit | jimsuhr | General Electronics Discussion | 45 | 09-10-2008 11:01 AM |
| DRO equipped Mill retrofit | Paraprop | Vertical Mill, Lathe Project Log | 14 | 02-15-2005 10:05 AM |
| knee mill conversion | mtechserv | Knee Vertical Mills | 6 | 12-04-2004 12:30 PM |
| Knee Mill - Z Axis Options | Moondog | Knee Vertical Mills | 3 | 11-17-2004 12:03 PM |
| Prospects of CNC for grizzly knee mill | spunkrat | General Metal Working Machines | 6 | 06-03-2004 11:17 PM |
