| Knee Vertical Mills Discuss Knee Vertical Mills here. |
The previous owner of our Alliant RT 2V Vertical Mill (Bridgeport clone) broke off the Feed Reverse Knob Assembly from the Reverse Clutch Rod and damaged the rod to the point where it needs to be replaced. We have ordered both the Feed Reverse Knob Assembly and the Reverse Clutch Rod and need instructions replacing the rod. Can someone step us through the sequence of disassembling gears and shafts to replace this rod? Thank you in advance! |
| find the following web site. I am in the middle of doing the same thing on my Comet (bridgeport clone). you take every thing out of the head and the last part lift is the reverse rod shaft and gears! tom Jelly did a real good job of photo doc. of the whole tear down http://home.comcast.net/~tom.jelly/j...%20rebuild.htm (if the site doesn't work just cut and paste i the address Last edited by oeffner; 05-07-2010 at 11:09 PM. Reason: website |
| Clutch and Downfeed Removal for CNC? | Cartierusm | Bridgeport and Hardinge Mills | 2 | 03-17-2009 02:20 AM |
| Bendix clutch | Chubs | Jet Engines and Ram Jets | 9 | 10-02-2007 11:02 PM |
| found clutch | mdreitzusa | Mechanical Calculations/Engineering Design | 7 | 09-30-2005 11:35 PM |
| Electic clutch | Konstantin | General Electronics Discussion | 0 | 09-02-2004 12:12 AM |
