Results 1 to 9 of 9
Thread: best way to CNC the quill z axis
    Registered matridium's Avatar
    May 2008
    Ok I have a knee mill and I have figured out most of the things I need to do for the x and y. However I don't want to move the knee, I think it is crazy to move so much metal to drill, and mill, IMO, but I think moving the quill is a great idea. however I'm stuck, how does one calculate for ipm, and everything else you need in order to get the z axis to work in the same measuring frame as the x and y if If the quill uses a rack and pinion? Can I just measure the distance of teeth and how many revolutions of the pinion is need to move 1 inch? Any ideas?
    Mike
    Feb 2008
    Lightbulb Try this...
    Mike,
    Do you have a Machinist Handbook? In the 27th edition it is page 2033 you want to look at. Otherwise lookup the Gearing Section. This will give you the basic's for calculating the Pitch Diameter (PD). Once you have the PD you just muliply it by pi. That will give you the linear distance for one rotation of the gear. If the gear is clean and build correctly you can find the PD by the gears outside diameter times its number of teeth and dividing that by the number of teeth plus 2.
    Steve
    Registered Torsten's Avatar
    Nov 2004
    U.S.A.
    Smile
    Dose your Quill have a scale on it?
    The highest number on the scale would tell you how far it advances per rotation of the Handwheel.
    If not you can do a rough messurement by marking a position on the handwheel then do one full rotation on the handwheel and meassure how far the Quill has advanced.
    You can fine tune this later once you have the motor installed when setting up the Controller Software.
    May 2008
    Thank you Steve
    This is what I got
    I took the quill apart, and the gears outer diameter is: 1.65"
    The number of teeth is 26
    So if I take the 1.65 x 26 = 42.12
    42.12/(26 + 2) = 1.5042857142857142857142857142857 and this is the PD
    Now if I take that 1.5042857142857142857142857142857 * 3.1415926535897932384626433832795 = 4.7258529489000746858588049751333 inches per 1 revolution of the gear.
    Now what I think I do next is divide that by the pulley I am gearing it down with. That is 2.5... I think you get to this by dividing the driven pulleys teeth by the motor pulleys teeth (in this case 25/10 = 2.5) so I have a 2.5:1 ration...
    So 4.7258/2.5 = “this is the distance the gear moves for every rotation of the output pulley? I think
    I guess all I need to do next is divide the output distance of 1.925" by my encoder feed back I believe that is 2000 because I have a 500 line encoder with a quadreture (4x)...
    So 1.925/2000 = 0.0009625
    So knowing this i can figure out the resolution of my Z axis
    If I take 1.925/0.000962 = 2001.0395 steppers per inch
    I should be able to use the resolution to indicate how many steps in software is used to turn the shaft 1"..
    I think this is right...
    I also looked at the distance and looked at the revolutions of the gear. And it appears to move about 4.8 inch for a full revolution..
    Thank you all for the help
    Mike
    Mike
    Feb 2008
    Thumbs up
    There you go... Torsten makes a good point though, most quill systems do use linear scales on the Z Axis.
    The rack will always have some backlash issues and there have been used a number of methods to minumize it, such as splitting the spur gear and loading them on the rack in opposite directions with set screws.
    Steve
    Jun 2006
    Here is a picture of a knee mill Z conversion.
    Hood over a Mach3 forum sent me several pictures
    of his conversion. I hope to do mine some day, but
    so far I get along using the rack and pinion.
    olf20 / Bob
    Attached Thumbnails Attached Thumbnails best way to CNC the quill z axis-hoods_bport_z.jpg
    Registered M250cnc's Avatar
    Sep 2007
    England
    Mike, IMHO you would be crazy to put effort into a conversion unless it had near to zero backlash as per the photo of Hood's Z axis conversion
    Phil
    May 2008
    Olaf
    do you have more pics of the Z axis conversion especially the quill part? i have decided to go with a lead screw... and split nut for now. I will upgrade to ball screws in the future as fund permit.
    Mar 2004
    St. Louis, MO
    Quote Originally Posted by matridium View Post
    Mike
    The typical rack and pinions have so much slack in them through the multiple gear trains that they are useless for CNC. Assuming a machine similar to a Bridgeport, here's what I did :
    http://pico-systems.com/zaxis.html
    I get about 0.0015" of backlash with this setup. To see how bad your mechanism is, just take a dial indicator and set it up to read vertical position of the spindle. Then pull the quill down and push up to see how much slack there is. There is generally NO WAY you can machine anything without locking the quill every time, it will creep up and down under cutting forces. Having to lock the quill totally defeats any way to make it work automatically.
    Jon
    1. Z Axis CNC: Quill vs Knee
      By SCzEngrgGroup in forum Bridgeport and Hardinge Mills
      Last Post: 11-29-2007, 04:47 AM
    2. Accurate Z-axis (Quill) Work on the Mill
      By BobWarfield in forum General Metalwork Discussion
      Last Post: 01-25-2007, 12:36 AM
    3. quill feed
      By BeeleJuice in forum Bridgeport and Hardinge Mills
      Last Post: 08-09-2006, 11:26 PM
    4. z Axis ---- Quill or Head?????? LATHEMASTER
      By bill south in forum Benchtop Machines
      Last Post: 06-23-2006, 08:22 PM
    5. Putting Z Axis CNC on Quill Vs Z table lift
      By Klean-Power in forum Bridgeport and Hardinge Mills
      Last Post: 03-26-2006, 04:11 PM
