BTW, if the 4400M uses drives that take a +/- 10vdc signal, you might be able to re-use them with this board: http://www.cnc4pc.com/Store/osc/prod...products_id=58
I would check with Arturo (the owner of CNC4PC) to make sure it will work, but that would be the easiest/cheapest conversion....
Chris.
