- Need Help!- Lagun FT-1 Vertical Turret Ram Knee Mill ????
I have acquired a bit of a Frankenstein machine.
I believe it's an early model Lagun with a Bridgeport Variable speed J -head.
The question is regarding the serial number.....
Mine is 4 digits. Everyone else's seems to be 5.....
Any help identifying the base so I can start looking for the correct manual would be helpful.
I did decide this must be a FT-1 based on the length of the bed. It's the only thing it could be.
But there are a couple subtle differences in the drawings, anx I've looked all over for one with similar badging with no luck...
My name placard logo thing on the side of the ram is different from any lagun I've found anywhere.
Will try and figure out how to post pictures....
Re: Lagun FT-1 Vertical Turret Ram Knee Mill ????
Serial number on the y-axis reads:
SE-4526
- You may not post replies
- You may not edit your posts
Forum Rules
