Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Kellyware CAM
Kellyware CAM Discuss Kellyware CAM software here.
Old 06-09-2009, 12:51 PM
majk2302 is on a distinguished road
imported g-code very small when in mm
hi,
i'm a newbie and i've playing around with different programs these past few days. i've found KCAM to be one of the best for me for now.
However, I do have one problem. I used the programme IMG TO G-CODE to get a g-code which i then imported into KCAM. when the dimensions in KCAM are set to inches, the image is its normal size (the size it was in IMG TO G-CODE). but when i changed to metric (mm), the picture is 5mm. what is the problem?
i hope you can help me.
thanks
Old 09-13-2009, 05:59 PM
ali_aldeen is on a distinguished road
YOU CAN SCALL AND OFFSET THE PICTURE IN KCAM TO NORMAL SIZE UES FUNCATION SCALL GCODE AND OFFSET
DFX is not imported correctly... ihkim GRZ Software- MeshCAM 11 01-07-2010 12:57 PM
Can't use imported DFX or DWG files cijunet GibbsCAM 4 10-07-2008 08:00 PM
Changing imported files cncuser1 Mastercam 3 04-11-2007 08:09 PM
DXF files imported to Autocad Spitfire Autodesk Software (Autocad, Inventor etc) 10 09-27-2006 10:32 AM
imported rotary tables vacpress General Metal Working Machines 8 04-06-2004 11:03 PM
