Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Kellyware CAM
Kellyware CAM Discuss Kellyware CAM software here.
Old 11-17-2007, 03:26 PM
shulio is on a distinguished road
Manual Control
I cant move manualy the axis.The yellow arrows don't work.When i press it the only thing that changes is "feed".How can i fix that
Old 01-08-2008, 06:14 AM
mlind is on a distinguished road
Double check your port pin settings. If you aren't sure what they should be go to this page http://www.stepperworld.com/pgSoftware.htm and scroll down the page for the settings. Make sure your Y-enable is set to true with all others set to false. If it worked before and doesn't work now reboot the computer. If a reboot doesn't work re-install Kcam and setup everything from scratch.
If it never worked the port settings is very important. Hope this helps.
I NEED: DX-32 manual, 1104-2832 VMC Operator's Manual, DX-32 CNC Control vettespeed Bridgeport and Hardinge Mills 25 05-01-2011 07:50 AM
Looking for hardinge vcm 1000 with fanuc 0-md control maintenance manual samu Bridgeport and Hardinge Mills 5 09-02-2008 09:36 AM
I need operating Manual for WS WSUw\GN 10TF Control metx Fanuc 2 10-04-2007 03:47 PM
control manual PatM Mazak, Mitsubishi, Mazatrol 1 07-16-2006 12:32 PM
looking for manual for boss 9 control zfair Bridgeport and Hardinge Mills 1 11-15-2004 11:30 AM
