Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Kellyware CAM
Kellyware CAM Discuss Kellyware CAM software here.
Old 10-08-2007, 07:29 AM
amakarevski is on a distinguished road
Talking kcam4-l297uni
i forgot ,travell speed 5m/min(200inch/min),cut 0,7m/min. trough 2cm wood like butter, no lost steps.(woodrouter is whith leadscrew and bigger(plasma) is with rack and pinion)
Kelly says:
Step pulses from KCam can sound uneven or lost steps are suspected. Here are some things to reduce this probem:
In the KCam's Table Setup window:
Check the Hide Axis Cursor parameter
Check the Disable Position Update parameter
Check the Limit Switch Disable parameter
Change Application Priority to High
Be sure to use the Ramping feature to avoid lost steps
In MS Windows:
Disable the Local Area Connection (NIC)
Exit all other applications
Disable other applications or 3rd party tools from starting with Windows
Stop unnessary Services in Windows with an easy to use script: http://www.kellyware.com/anonymous/S...icesScript.zip
it works much smoother without jerks.
kcam4 and pminmo l297-unipolar contr. amakarevski Kellyware CAM 4 10-31-2007 11:28 AM
