Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Kellyware CAM
Kellyware CAM Discuss Kellyware CAM software here.
Old 10-08-2007, 06:27 AM
amakarevski is on a distinguished road
kcam4 and pminmo l297-unipolar contr.
hello,
I build two cnc machines one is 2,5 m by 1,5m wood router and other is 4,5meters by 2,5 meters plasma router.both work with kcam4(demo) and pminmo l297 unipolar controler and they work excelent!i also try a mach3 but i am more satisfied with kcam ,it is easier to control,more stable and less confusing.mach3 is faster ,smoother(litle) but has very bad(miserable), user interface and bad ploting-view of tool path.kcam4 also have some problems but they are easier to solve.the pminmo l297unipolar driver work excelent in half step mode,smooth,without any misssteps or other problems.i use 3amps 3nm steppers on wood router and 4amps 8nm on bigger machine and my fets(irf640) get only slighty worm.
so i recomend kcam4 to all new cnc builders becouse it is much easier to work with it.mach3 is very fast ,smooth but with that preview off toolpath i dont like it.
soon i will post some pictures and video off working machine.
ps.excelent job pminmo and kelly, thanks!
Old 10-08-2007, 12:07 PM
EMMKAY is on a distinguished road
Congratulations on getting things working nicely. Can you give some more details such as what Power Supply you are using with the pminmo controller, what IPMs are you getting out of your setup and did you say that you are using irf640!!! did you do any changes to the unipolar board or not.
cheers
EmmKay
Old 10-09-2007, 04:55 AM
power suplly 49v dc,200ipm travel speed,only change i made is transistor stabilisator after the 49volt power suplly to reduce it to 25 volt for 7805 3pin regulator for board logic.choper works great only litle heating on fets(off course with heat sink,3cm by 4cm 3mm alluminium plate for each fet).fet irf 640 work great, total gate charge:55nc,gate sourse 10nc,gate drain 21nc.
irf 540:total gate charge 72nc gate source 11nc,gate drain 32nc so irf640 need less current to turn it on,but you MUST use hct series ic's and not wire wound resistors for current sensing(0,1-0,2 ohm)
Old 10-09-2007, 09:45 AM
pminmo's Avatar
pminmo is on a distinguished road
Originally Posted by amakarevski View Post
hello,
Excellent! Would love to see some pictures.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 10-31-2007, 11:28 AM
Khalid's Avatar
Khalid is on a distinguished road
I used KCAm but it is best suited for beginer. Currently i am using MACH3 and my machine run faster twice as compare to KCAM.
L297 Controller for Unipolar Drives shahidmk Open Source Controller Boards 50 10-02-2011 02:22 PM
l297 7amp unipolar driver ljd10 Open Source Controller Boards 13 10-09-2007 08:56 PM
Pminmo electronics SCHootie Open Source CNC Machine Designs 13 02-23-2007 10:40 AM
Questions for pminmo dfro PicStep Controllers 0 07-01-2006 11:14 PM
L297 for unipolar? Mcgyver Open Source Controller Boards 31 12-10-2005 01:13 PM
