Dave,
I also use Kcam and I also have his Max Stepper setup and it all works great. You are right it was the only sotware I was able to get to move any of my step motors I guess that's why I own a copy of it. Your step motors are 200 steps per revolution of the motor. The way I set mine up was in steps per inch. I had to figure out how many revolutions of the motor it took to move the lead screw nut 1 inch and then put that number in the box(ie: 1 revolution =200, 1.5 =300, 2=400 and so on). I am also running a belt driven gear box at 2:1 so I had to take that into concideration also. If you are just setting it up on the bench to turn the motors and they are not hooked to a lead screw I think the program comes with some basic info inputed in the windows and that should get things turning until you have the motors hooked up to a lead screw to get the correct info in the boxes. If you still have problems please go to Kcam web site and there is a support forum that will be happy to help you get it set up and running. You can also down load the owners manual for the software and it will help also. Jeff
LinkBack URL
About LinkBacks
