Results 1 to 3 of 3
Thread: Does K-Cam read "D"?
    Apr 2005
    "D" as "tool radius compensation number".
    If so, I would need to use G41 or G42 ?
    What would a lind of code look like profiling with a Ø.25 Endmill?
    Thank you for any direction or help.
    Charlie
    Mar 2003
    Shelby Twp, MI....USA
    Apr 2005
    Thank you Gerry.
    According to that Kellyware example you posted, someoneone loaded a DXF into Kcam and got a G-Code complete with Cutter Compensation!
    I have never been able to use what K-Cam gives me because the "Z" axis is called for after every few lines, and the G-Code is jumping up and down, running all over the place!
    When I load a tool from the tool box, it will compensate to the left, then to the right, and often goes in little circles from one line to another, so I have not been able to use K-Cam in this manner at all.
    I can load a part profile (G-Code) written by another program and K-Cam will run the Stepper Motors from it, but when I try to use Cutter Compensation, It goes crazy, So what I load is what I get, any changes I make, I need to do it before giving it to K-Cam.
    I love the big display and the CNC Controlls, but use it to run the stepper Motors only.
    Surely, I just don't know how to use it, as I said, I love the display.
  1. "NEW" 1/8" 5 FLUTE CARBIDE END MILL "AlTiN"
    By CNCadmin in forum EBAY ADS
    Last Post: 11-06-2011, 02:00 AM
  2. Need Help!- "absolute" position doesn't read correctly
    By Joe.B in forum Fanuc
    Last Post: 09-26-2011, 05:46 AM
  3. Need Help!- Control will "punch" but not "read"
    By dansteinmetz in forum Fanuc
    Last Post: 04-06-2010, 05:10 PM
  4. Macro to read machine "power on"
    By jakk100 in forum G-Code Programing
    Last Post: 04-12-2007, 10:15 AM
  5. Relocate "mark forums read"
    By pminmo in forum Suggestions for the CNCzone.com site.
    Last Post: 02-18-2006, 01:27 PM
