Greetings, I am adding home and limit switches to a Zenbot and I am using Kcam. Should the switches be normally open or closed? Thanks in advance for any help received.
Select a method which is most foolproof. If a wire breaks on this circuit, will the machine know the difference between the normal and the abnormal condition? And do you care if it knows?![]()
