Hello,
I'm a newbie when it comes to CNC, but i'm trying
When I export a drawing from Corel Designer 9 (i'm using build 9.0.2.0314) to DXF, not only the piece but the entire sheet is exported (even if i select the piece i want to export). The result is, that when I import the DXF in KCam, compiles it and makes a test run, the machine wants to cut out a "letter" sheet, and then my work piece inside of it...
Have I missed some settings, or is my approach wrong?
- Magnus
LinkBack URL
About LinkBacks
