Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Joes CNC Model 2006
Old 01-16-2010, 11:37 AM
In-Spec is on a distinguished road
Unhappy Z bearing block
Can anyone shed some light on the errors I found regarding the Z Bearing block.
Spacing for the 4 U-bolts differ from Acad drawing to solid. Instruction say to bend u-bolts closed to 4-1/4". Spacing is only 2-1/2" on Acad, and 2-1/4" on solid. What is he talking about? I'd hate to scrap this pricey sheet of delrin
Old 01-16-2010, 09:13 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
you will need to compress the u bolt to the correct dimension, i could not find a 2 1/4" one myself and had to use a slightly larger one.
Thanks,
Joe
www.joescnc.com
joecnc2006 at yahoo
Old 01-17-2010, 12:15 AM
Thanks for the reply. I understand what you're saying, it's just that I used the .dwg drawing in your plans to machinine the block at 2-1/2" u-bolt spacing, which differs from the e-drawing dims of 2-1/4"
2d milling for bearing block eloid DIY-CNC Router Table Machines 5 08-12-2009 08:26 AM
Bearing Block design devincox Industrial Hobbies (Support forum) 27 04-02-2009 09:35 AM
How to cut a bearing block ? ringram2077 General Metalwork Discussion 14 04-02-2008 09:49 PM
Help with bearing block margni74 Linear and Rotary Motion 4 08-11-2007 04:47 PM
Bearing Block Question Moondog DIY-CNC Router Table Machines 4 08-22-2004 06:06 AM
