Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Joes CNC Model 2006
Old 01-07-2010, 11:05 AM
trey is on a distinguished road
New guy, planning to build a Joes 06
Hi everyone, I'm Trey. I came across the Joe's 06 a few years back, and wanted to build one then. I kinda dismissed it, but the urge is back. I have never used a CNC machine before, let alone built one.
I am considering this for the electronics...
http://www.xylotex.com/Econo3AxSpecial.htm
Will probably upgrade to 5 start lead screws, and anti backlash.
The plan for the machine right now is mostly going to be balsa and light plywood. I also found some clocks many years back that I wanted to build, so maybe some of those too.
Looks like I am going to have a lot of questions. I will probably be starting this around the first part of Feb. Tax returns!
Old 01-07-2010, 11:26 AM
ger21's Avatar
I think the Xylotex is underpowered for 5 start screws. I'd recommend a G540 if you'll be using those screws.
And I do have a Xylotex on my machine.
Old 01-07-2010, 11:34 AM
Would you say this is probably a better setup then?
http://homanndesigns.com/store/index...products_id=90
Old 01-10-2010, 07:01 PM
AJ Negvesky's Avatar
AJ Negvesky is on a distinguished road
I went with the probotix kits
http://www.probotix.com/3_axis_stepp...or_driver_kit/
they have been very helpful and prompt with delivery. I had one of their stepper drivers go bad and they sent me a new one the next day FREE to replace it.
I am using 1/2 5 start lead screws from McMaster-Carr and the rest of the hardware from Dumpstercnc leadnuts couplers and collars. with this setup I have had tremendous luck.
Old 01-19-2010, 11:24 PM
yakker is on a distinguished road
Balsa and light plywood....are you planning on cutting rc airplanes?
Old 01-19-2010, 11:36 PM
MyCattMaxx's Avatar
MyCattMaxx is on a distinguished road
If made out of balsa and light plywood he may be able to cut paper.
Old 01-22-2010, 12:36 PM
mlabruyere's Avatar
mlabruyere is on a distinguished road
I think he meant the machine will be purposed to cut balsa and light ply not be built out of those materials....
Old 01-22-2010, 12:37 PM
mlabruyere's Avatar
THat's what it sounds like to me as well.
My Joes 4x4 build lsalme DIY-CNC Router Table Machines 2 08-01-2009 07:26 PM
Researching/planning 4x4 plasma build Oakley1975 Plasma, EDM and other similar machine Project Log 0 01-01-2009 04:28 PM
Joes 2006 Build Thread DistortedDesign Joes CNC Model 2006 2 09-02-2008 11:16 AM
Newbie- Planning to build a CNC router blue_can DIY-CNC Router Table Machines 26 06-10-2008 05:45 AM
Anxious To Build Joes CNC Post1952 Joes CNC Model 2006 17 05-19-2007 09:52 PM
