I built a Joe's CNC 2006 a few months back and finnaly got around to using it. I used it to cut out all the parts for another because the first one I cut all the parts out by hand on a scroll saw and table saw. All the new parts turned out alot better. I'm putting it all together now. Main thing I dident do on the first one is square flatten everything, mainly the table. Anyways I need help right now with some tips as to get the main table perfectly flat. When I put a level across the table it wobbles because some of the ribs stick up ever so slightly. What did you all do? (picture attached) |
Use a flat surface and build it upside down so the top side is flat and even.But now that you're done, the easiest way might be to use a handheld router. If possible, lay some strips of MDF on either side of the high ribs and rout them flush. If it's too uneven to do that, you can try something like this to flatten the whole thing. http://www.highlandwoodworking.com/f...tharouter.aspx
| Newbie- Square hole in square tube | bubblybill | General Metalwork Discussion | 6 | 09-20-2009 10:18 PM |
| New Machine Build- How do you get a table FLAT, TRUE & SQUARE? | WSS | CNC Plasma and Waterjet Machines | 25 | 07-28-2009 11:24 PM |
| 100% flat table for flat bed lamination | Bernhardsen | Printing, Scanners, Vinyl cutting and Plotters | 4 | 08-24-2008 08:31 AM |
| Build cnc router without linear ball bearings ?? Flat metal on flat metal with lube ? | vroemm | Linear and Rotary Motion | 7 | 08-16-2007 12:26 PM |
| How to make Parallel Square Beam/pipe without flat surface ? | Calico | Welding, Brazing, Soldering, Sealing | 8 | 06-26-2005 08:13 PM |
