Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Joes CNC Model 2006
Old 11-17-2009, 12:56 PM
Rooney is on a distinguished road
Joe's 2006 Question on size of cutters machine will handle??
Long time since I last posted. Hello All!
Question.......
I bought this.....
Amazon.com: WHITESIDE MACHINE 1100 CARBIDE-TIP 2 FLUTE STRAIGHT ROUTER BIT 1-3/4 DIA X 1-1/4" CL X 1/2" SH X 3": Home Improvement Amazon.com: WHITESIDE MACHINE 1100 CARBIDE-TIP 2 FLUTE STRAIGHT ROUTER BIT 1-3/4 DIA X 1-1/4" CL X 1/2" SH X 3": Home Improvement
Since the Hitachi will only go down to 8000 rpm.....is it safe to use this tool for facing the spoil board??
I'm really nervous about even turning the thing on with that cutter as it weighs half a pound. Any recomendations would be greatly appreciated.
Edit: I understand about having to do with speeds and feeds and chip load so on and so forth. I'm just wondering what the hitachi will handle? Do I need to make sure the family is out of the house? Or stand behind my imaginary forklift? That's what my buddy says that he does. But he really has a forklift. I'd have to hide behind my freezer and turn the thing on with a long stick.
I guess I wasn't nervous until I realized how heavy the tool was.
Old 11-17-2009, 05:17 PM
ger21's Avatar
You should be able to run it at 12,000 -15,000 rpm, but I'd run it at 8,000-10,000. Depends on the feedrate you plan on using.
Just make sure it's tight. If you're concerned, place a piece of MDF between you and the router when you turn it on.
Old 11-18-2009, 07:49 AM
Thanks, Ger
I still need to finish my impromptu dust collection before I do this. I feel better now, but I will still be holding the mdf in front of me
Thanks Again,
Rooney
Old 11-18-2009, 08:52 AM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
Very good Idea, Also can use bullet proof glass
Old 11-19-2009, 10:55 AM
I am actually thinking of some part lexan part mdf removable walls. The less lexan the better though as it is expensive.
Glacern Machine Tools - Vises, Toolholders, and Indexable Cutters Glacern Product Announcements & Manufacturer News 8 09-28-2009 04:57 PM
LETTERING HARDWOOD CUTTERS? AND PLYWOOD CUTTERS andycorleone WoodWorking 2 12-12-2008 12:36 PM
Hey Sign makers (question on vinyl cutters) Darren_T DIY-CNC Router Table Machines 12 11-18-2008 12:43 PM
Question On Cutters for 304 Stainless Aand55 General Metalwork Discussion 7 11-19-2007 03:00 AM
Cutters for Wood Question paulried DIY-CNC Router Table Machines 9 05-13-2003 01:05 PM
