Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Joes CNC Model 2006
Old 11-04-2009, 04:49 AM
stekke_stim is on a distinguished road
First cnc
Hi all
I'm Stijn I’m 18 and I’m from Belgium and I'm going to build my first CNC router.
I want to build one because buying one is much too expensive for me.
First I’m going to build the structure so I can decide when It is finished witch motors I’m going to use.
But I already have been watching at several online shops for the best quality/prize.
And for my project I think THIS is the best one.I have a budget from 500$ (+- 330 euro) for motors, drivers, … including shipping.
I chose Joe's model because I like the design.
I'm going to build it from 18mm thick mdf panels, this means I’m going to make some slight changes in the design.
I need to cut all pieces by hand.So this project is going to take some time to accomplish because I also got a fulltime job.
Because today I don’t need to go to work I’m going to try start cutting the first pieces from the Y–axis torsion box.
I will try to post some photo’s when finished with the first piece.
Here we go....
Greetings from belgium
Old 11-06-2009, 04:29 PM
Progress
Hi all me again
Yesterday I took some pictures of my temporary workshop our workshop is in the backyard but there is no heating in there so my temporary workshop is in the garage now
I also finished 3 ribs from the y-axis torsion box and i did +- 7 hours over those 3 pieces (pictures from this: tomorrow.)
I'm cutting these by printing the piece, putting it with tape on the mdf panel and going with a knife over the black lines. Then i take a pencil en draw a black line against the outside of the cutting. Afterwards i take the large router and grind around the lines, and finally I take my dremel for the details.
Old 11-16-2009, 09:34 AM
cnc kit
I have found a seller on ebay with a nice stepper kit:
3x NEMA23 2ph 22kg.cm Step Motor
Maximum Holding Torgue 308 OZ / INCH
Size : Dia 56mm X 81mm Long
Double Shaft : Dia 1/4 Inch X 3/4 Inch Long
3x Turning Knob for Manual Control
3x 4.2A Industrial Grade Mirco step Drive
Mirco step form 400 to 25000 step per Revelution
1x 36v 10A Power supply
DC:24 to 50V
AC Input: 90 to 240V
Power Can Supply up to 4 Axis
1x CNC SOFTWARE BREAKOUT BOARD
Build in 5v 1A Power Supply for Control Signal
IDEAL FOR CNC PARALLEL PORT SOFTWARE
TURBOCNC, KCAM, MACH3 etc
1x PARALLEL PORT CABLE
1x PANIC STOP BUTTON
Weight About 6.5 KG
http://cgi.ebay.com/Cnc-Mill-3axis-P...item5ad43684ef
Does this seems interesting?
525$ including shipping to belgium
Old 11-16-2009, 09:58 AM
lumberjack_jeff is on a distinguished road
Those drivers look like mine.
So far, they work well.
http://www.driver-motor.com/ProductContent.aspx?ID=59
I used a PMDX breakout board
http://www.pmdx.com/PMDX-122
For power supply, I built my own sized to match the needs of the stepper.
http://www.mechmate.com/forums/showthread.php?t=56
The voltage of the power supply should be 32 times the square root of the motor inductance. So, for a stepper with a published inductance of 1.5 requires 39 volts (32 x √1.5 = 39 Volt)
I rewound a microwave oven transformer.
http://www.mechmate.com/forums/showthread.php?t=1185
Check out the mechmate forums for some good DIY power supply advice.
Other than the breakout board, I don't see anything in the Ebay kit that I'd consider questionable, but you might be able to get the stepper drivers cheaper by ordering directly from Hong Kong.
Old 11-16-2009, 02:58 PM
i'm not an electronics genius to build my own power supply
the breakout board is considerable but if it isnt working ; a breakout board isnt that expensive.
And what do you mean by ordering directly from Hong Kong?
greetz
Old 11-16-2009, 04:37 PM
I'm certainly no electronics expert either, but the posts on the mechmate forum enabled me to do it with no sparks at all.
A basic PS is simply a transformer, a rectifier and a capacitor.
http://www.mechmate.com/forums/showthread.php?t=350
It was actually quite a good learning experience.
The driver-motor link is to a Hong Kong distributor.
I really like the PMDX BOB;
a) the documentation is good
b) the device is proven
c) BOB problems are difficult to diagnose, and documentation is critically important.
It's really the only thing I didn't "cheap out" on.
Old 11-23-2009, 09:32 AM
yngndrw is on a distinguished road
I'd suggest just using the supplied power supply as it's a switched mode power supply. A switched mode power supply has a few benefits over a linear power supply:
1) Power regulation is usually better, although in this case it doesn't matter.
2) Size, they are much smaller.
3) Weight, they are much lighter.
4) Sometimes cost, depends.
5) Running costs, they waste a lot less power.
Of course, it's always fun to build stuff.
For the creation of the ribs, from what I can see I think you are cutting each one out by hand. For any parts which are the same, you should think about making a template out of thin wood then using the router to follow the template. If you're already doing this then sorry, I misread it.
