For about a year and a half I'm running the beginners setup with a Acme 1/2-10 single start screws and I'm getting tired of the lack of precision and the overall play within the machine movement. I's a fine setup for the money invested but I'm stepping up. I'm fixing to get rid of all the MDF except the table that is solid and bolted to a steel structure and go with real linear bearings. I followed the previous post talking about the issues with 2 & 5 start screws trying to find out what would be good precision screws without going bankrupt so I wanted to create a separate post just dealing with precision instead of speed. My second issue would be the movement of the machine when it's cutting a curve or a circular pattern. This does not happen with small radius patterns but on the larger ones the machine does not follow the curve cut in a smooth motion and it travels in waves as it receives the information from Mach3. It does not have the constant velocity on curved patterns (diagonal straight cuts are fine) and I know there is a setting for CV in Mach3 but if I set it on then my sharp corners come up rounded. |
One thing you can try with CV mode. Go to the settings page, and make sure CV distance and CV Feedrate are turned OFF. Then, go to General Config and uncheck all the CV settings except the last one. "Stop CV on Angles>". Check this and set it to 89°.
Thanks G for all the info and for saving me $ I don't have. |
Also, draw a circle in Corel and upload the .dxf here too.
| Try running this code and see if it runs smoother? It doesn't go below Z=0, so it shouldn't cut anything.
I drew a simple circle and an arched with a closed line between the endpoints so here are the DXF files from AutoCad 2009 (saved as a 2004 version) and Corel (also save as a 2004 Version) and the corresponding toolpaths. There's also a post processor file from Artcam that I did the toolpaths with. |
| two problems. One, that ArtCAM Post will not output G2/G3 arcs. Not sure if it can be changed to do arcs. Second, the circle from corel is actually an ellipse, and the arc is a spline. typically, both of those types of entities will give you straight segments, and not G2/G3 arcs. You might want to try my AutoCAD macro to export g-code from AutoCAD. You need to convert arcs to polylines, but circles are fine. It's quick and easy once you get the hang of it. http://www.cnczone.com/forums/showpo...&postcount=196
| If your cutting reliefs, you'll always get G1 moves, so a different post processor won't matter.
#10
![]() Usually the relief objects get a rough cut and I use the same bit to do the exterior perimeter cut and the two toolpaths are saved under a single g-code file since it's the same bit. I was testing different post processors and Mach3 Arc and G-Code Arc were able to produce a G2 even from a Corel file. It would split a circle into 4 sections (even the AutoCad circle) and the arc with a single radius would be done with a single line of code. I did another arc looking thing but it was more like a half of an oval and it did split it into segments since there wasn't a single radius there. Thanks for leading me in a right direction |
| fixed screw vertical movement | mccafferty | Linear and Rotary Motion | 14 | 01-25-2009 02:11 PM |
| Manual Ball Screw Movement | dafowfidy | Haas Mills | 0 | 12-10-2008 09:33 AM |
| newbie question xyz and tool movement direction | LockTech | Mach Mill | 1 | 06-15-2008 12:18 PM |
| Mach 3 Jog movement question | Drakkn | Mach Software (ArtSoft software) | 2 | 11-30-2007 04:21 PM |
| acme screw to ball screw question | Billw | DIY-CNC Router Table Machines | 9 | 07-18-2005 12:10 AM |
