Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Joes CNC Model 2006
Old 06-14-2009, 03:17 PM
Realmseeker is on a distinguished road
Pre-build, need advice please
Howdy folks,
With the Canadian dollar going up, and my job situation stable, I can now start buying and preping for a Joe 2006.
I plan to basically stick to the plans with a few changes I have seen other people try. I would like some input on a few things I plan to buy and routes I will take.
I plan to use the router for an assortment of tasks. I want to be able to work with both hardwoods and MDF. I hope to be able to do guitar bodies and necks, some vcarving(or some sort of 2.5d graphics), and small parts for assorted hobbies. I figure I need 100 ipm cutting from what I understand and read from other logs.
I own a 2.25 hp bosch router. I plan to use this for my spindle. I figure I need to but a 1/8 collet. At this time I am not sure what to do about bits, what type I need, and where to get collets. I have seen one website, but I hope to be able to acquire parts through my work for that.
Changes from the plans I care to make is to go with a torsion box. a majority of the build will be 1/2" MDF. A few parts look to be 3/4" MDF. The torsion box will be built with 1/2" supports and for the top and bottom skins.
The drivers are going to be HobbyCNC 305oz kits. I want to use them on 1/2"-10 5 starts. Is this a good motor/screw combination or do I need something stronger. I'd rather get a 1/2"-10 2 start or such then try to find a stronger motor. This is primarily because HobbyCNC is in my price range and have a full kit. I'll power it with the computer
Should I go with lovejoys or will using the flextube as a coupler good enough? The price doesn't seem to prohibitive considering the rest of the expenses.
For the slides I plan to go with the skate bearings on metal angles.
Software is still to be determined. I am considering Mach3, Cambam, and I can have access autocad and googles sketchup. I plan to get a P4 for mach 3.
I am not sure what else I am missing or forgetting. I had to side line this for the last few months. So please comment and tell me what I am missing and ideas I should change. I plan to get the acme screw at mcmaster-carr. If anyone knows a cheaper place that carries the 5 start please suggest. I figure I need 12 ft (2x 6ft lengths). Also I am having troubles finding the 5 starts on their site, can someone link it please.
Have a good one,
Jordan
Old 06-14-2009, 03:20 PM
One last thing I forgot. The tools I have access to. I have a fairly well equipped shop. Table saw, drill press, thickness planer, jointer, mitre saw, bandsaw, and an assortment of hand tools. I am a cabinetmaker by trade as well.
The rails I plan to use standard steel pipes. Is there any way to clean them up and sand uniform with out a lathe?
Old 06-14-2009, 08:07 PM
ger21's Avatar
If you read through some of the threads here, you'll see how a lot of guys made sort of a makeshift lathe using a drill to spin the pipes while they sanded them.
McMaster part #'s for 5 start are:
99030A704
98940A204
Page 1093
But, they probably won't ship to Canada.
As an alternative, you might want to look at Roton's 1/2-8 4 start. Both are 2 turns per inch. Roton also has 1/2-8 2 start. That might be a better choice with the HobbyCNC kit. with a 36V power supply, you should be able to reach 100-150 ipm.
Another New JGRO Build - Advice Sought... dbprojects JGRO Router Table Design 43 02-14-2008 09:38 AM
Need Help!- Need advice on router table build jdcn05 DIY-CNC Router Table Machines 2 01-27-2008 04:02 PM
Looking for advice on first cnc build MAAD DIY-CNC Router Table Machines 3 01-24-2007 10:33 PM
I would appreciate some build advice Tom Brown DIY-CNC Router Table Machines 3 09-04-2006 08:24 PM
