I have been a weekend woodworker for about 6 years now and after seeing the rockler CNC Shark I started researching and reading as much as I can on the cnc shark router then stumbled on Joe's website which then linked me to this site. All I have to say is WOW after reading too much my head is now spinning in every direction. so I guess I finally did decide on the Joe's 2006 R2 model because of space constraints in my workshop. before I pull the trigger to start the build I want to get my list of parts together and vendors to calculate the cost of the build. I estimate that I may have $1500 for my build. I have found some assembly instructions but they are dated 6/1/2006, is there any more updated BOM or assembly instructions for the R2 version? what parts are recommended to upgrade or is there a master list I can pick and choose from? the electronic parts that I am looking at is a 3 axis hobby cnc pro 305oz kit or the gecko G540 with the same motors from the hobby cnc kit. should I go with the 4 axis kit or some other motors/kit? For the XY rails I was looking at the 1" OD NB Linear rod (kit8009) from vxb.com, will this work better and be more accurate than the gas pipe solution for the XY rails? I will most likely go with a 2hp+ PC router with the precise bits collet set. thanks James |
| The cost of my machine was just a little over $700 and that included everything but the actual router. Normally I did all the cutting in order to save a few dollars. If I was to start over again I would invest a little bit more and go with linear bearings instead of the regular skate bearings with aluminum angle. There are plenty for sale on e-bay if you are patients and you can get them dirt cheap including the bearing blocks. What really matters is what will you use the machine for. If it's just for woodcutting you can go with the original design without a problem. If you ever decide to cut some 1/2" aluminum plate, that is when you will wish you had some linear bearings but if you are ready to spend $1500 do it right the first time around. There are so many mods that it would probably fill 150 pages on this forum so check them all out before you start. I don't know if I have seen this on 2006 model but it is very useful do go with dual screws for the X axis like on Joe's 4X4, without dual motors but with some gears and belts between the two; it's minimal expense and it ensures even movement especially if you are cutting hardwoods. Good luck and I know you will be enjoying every minute of it and if you get stuck on something send me a PM and I'll see if I can help you out. BTW, that little CNC at the woodworking supply place is a $3500 joke and a pure waste of good material Last edited by Astor123; 04-04-2009 at 01:08 PM. Reason: Added info |
| I just made two threads "sticky", so you can find them at the top of Joes forum here. How much does it cost? and Mods and Additions
I'm in the same situation as you. I want a solid machine for woodworking. Looking forward to starting my build. Sounds like your plan is along the same lines as mine. I'd appreciate hearing your progress! Keep us posted here. Gleaning info from all the threads is a bit daunting of a task. Jim |
| There is a good parts list on the Joes forum. Even if it is dated 2006, not much has changed. The good one is an excel spreadsheet. I say use the pipes as in the design. Linear bearings and rails, etc would be hard to adapt, I think. Stick with the Hitachi router, if you want an upgrade, get the Milwaukee 5625. I am not a big fan of PC routers. http://www.cnczone.com/forums/showth...t=43485&page=7 post 76 Upgrades from my point of view. K2cnc router mount and replace the MDF part the router mounts to with aluminum plate. There is a picture of this in my build thread. Beyond that, save up for Vectric software. Vcarve Pro or now Aspire are worth the investment. You only need Aspire if you plan to do 3D, and want to create your own. You can create in other software if you have it, and toolpath in Cut3D. Vcarve Pro is hard to beat. Oh, one more upgrade. Zero set and corner finder. http://www.cnczone.com/forums/showthread.php?t=56079 Look throught the upgrades thread on Joes2006 forum. Ask more questions. |
thanks james |
| James, I don't think you can go wrong with any of the Vectric products. All are available as a free download trial version that lets you try all the features. They are only limited by the ability to save, similat to the trial of Mach3. This makes it easy to see if you like them and compare to other products. As for routers, use the one with variable speed. If they both are variable, use the quieter one. I am pretty sure K2 makes mounts for both. The zero set and corner finder are almost free as you can make the parts at minimal cost. The software stuff is all posted and available. Just a mod to the Mach3 screen, and a macro to run. Start building and posting. |
| ok i am now on the fence and not sure what way to go as i have been reading quite a bit about the hybrid 4x4 as a 2x4. the space i have to work with is roughly 6'x4' so i was thinking about building the hybrid with the X axis as the 2' and Y axis as the 4', would there be any problems in doing this? also does anyone know what the actual footprint would be? deciding on what to make the base with either the unistrut or a base out of wood with cabinets, what is the costs of the unistrut? thanks james |
| James, I know this design has been adapted to lots of other dimensions. I think there are several that have built it as a 2 x 4. I can't give you a footprint. You can use either wood or unistrut amoung others. Unistrut is usually available at your local box store Lowes or HD. Check there to get the price in your area. You can also order it from most Industrial supplys. Try Mcmaster or whoever you like. |
#10
| The long rails are 72" I think, so a 2x4 would probably be ±36x72, maybe a little wider.
| Another Joe's 2006 Build in Ky | Lucan | Joes CNC Model 2006 | 23 | 10-12-2007 05:26 PM |
| My Second Router Build This time Joe's CNC Model 2006 | Catapultsup | Joes CNC Model 2006 | 4 | 08-17-2007 10:17 AM |
| Joe's 2006 in OH | fade2black | Joes CNC Model 2006 | 44 | 07-18-2007 08:46 PM |
| New build in Canada: Joe's 2006 | 300dt | Joes CNC Model 2006 | 2 | 07-02-2007 11:00 AM |
| Building a Joe's 2006 | jspencer | Joes CNC Model 2006 | 61 | 03-15-2007 08:14 AM |
