Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Joes CNC Model 2006
Old 03-05-2009, 11:35 AM
DistortedDesign is on a distinguished road
Acme Rod Question
Hey I had a question about the legnth of the acme rod for the Y axis and the Z axis. What legnth is the acme rod suppose to be for the Y and Z. I totally forgot that I am going to have to cut the acme rods to fit.
What is the best way for cutting them? I can see that they are ground on the end so that the threads will start.
Old 03-08-2009, 09:17 AM
Any one??
Old 03-09-2009, 06:39 PM
*Registered User*
Astor123 is on a distinguished road
Lenght to size
This is how I got mine set up:
I mounted the motor brackets, the motor, lovejoys, and popped the bearings in place but didn't align anything (this is just for the actual lenght). I measured from inside the lovejoy 3/8" pass the set screw, went across to the other side plus I left another 2" pass the bearing block. On that other end I have (against the bearing)a washer-spring-washer-nut with a set screw drill in it. This keeps the tension on the screw and eliminates some of the wobbling.
Old 03-10-2009, 11:05 AM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
Is this for the Model 2006?
Also you can cut them with a hacksaw and just use a hand file to tuch up the end so the screws start.
Old 03-10-2009, 11:18 AM
Sorry I should have said that yes this is for a 2006 and I have the love joys and the anti backlash nuts as well. I just wasn't sure about the legnth of the y and the z. My dad has one of the big metal cutting saws but I just wanted to check with the experts on this so I don't mess up one of the screws.
Acme Question Micky15044 Open Source CNC Machine Designs 4 07-11-2008 08:34 PM
Acme rod question THend Linear and Rotary Motion 5 03-21-2008 12:37 PM
ACME Leadscrew question whmeade10 Open Source CNC Machine Designs 21 11-28-2007 06:27 AM
acme rod question Kev DIY-CNC Router Table Machines 3 10-12-2006 03:26 PM
Acme nut question SPEEDRE Benchtop Machines 1 09-18-2006 02:23 AM
