Originally Posted by
BobF
jdell42,
I can push on mine and measure some deflection with a dial indicator.
How much is "a bit of deflection"? If you can measure it with a ruler, your bearings may not be tight enough. If you can measure with a dial indicator, its the same as most.
I cut at 100 ipm and rapid at 200. I have not measured z height changes with a caliper, but I don't see any during cutting. I have cut out parts with pretty tight tolerance on Z and been happy. Example, I cut a piece of acrylic for the corner finder and the tolerance of the cut is nearly immeasurable. The finished height of the copper pipe is dead on all around.
