Page 2 of 4 FirstFirst 1234 LastLast
Results 13 to 24 of 37
Thread: Started building joes 06
  1. #13
    Feb 2009
    what kind of spacers are between the bearing and the angle aluminum on the 06 r2 joes
  2. #14
    Registered Crevice Reamer's Avatar
    Mar 2008
    Looking good troach. Welcome to the Zone!
    Nice work, good pics, interesting read. Can't wait to see it run. What motors are you using?
    CR.
  3. #15
    Feb 2009
    i got the keling 3 axis gecko 540 kit i think they are 385 oz nema 23 bipolar motors with a 48v/7.5 amp power supply
  4. #16
    Mar 2008
  • #17
    Feb 2009
    Got some more pictures for everyone - 5 more wood peices to cut! and ill be ready to start painting.
  • #18
    Feb 2009
    hey joe what kind of spacers do you have between the angle aluminum and bearing?
  • #19
    Feb 2009
    bkboggy We wired up some of the gecko serials today and well the pdf and xml at www.geckodrive.com are pretty self explanitory on the wiring and setup for the g540 . if there is any question just ask!
  • #20
    Nov 2008
    Sweet, hope it all works. I'm going to be wiring mine hopefully in a week.
  • #21
    Feb 2009
    the only question I have about the g540 is how do you know how many steps per unit to put the motors on because the 540 goes on the fly 1/4 step 1/2 step ect. ?
  • #22
    www.joescnc.com joecnc2006's Avatar
    Aug 2004
    Quote Originally Posted by troach View Post
    they are 10 microstepping the other is a morphing feature.
  • #23
    Mar 2008
    200 x 10 x TPI = SPI. You must calibrate this in case of mechanical irregularities:
    Zero Mach axis DROs. Jog each axis a measured distance. Check that actual travel matches DRO. If it does NOT, then tweak steps up or down as needed. You can use decimal fractions if necessary.
    CR.
  • #24
    Feb 2009
    ill try that thanks!
  • Page 2 of 4 FirstFirst 1234 LastLast
    1. I just started building me a CNC router
      By mind_nl in forum DIY CNC Router Table Machines
      Last Post: 04-27-2008, 07:34 AM
    2. Thinking of building a Joes CNC 2006 in Brisbane Australia
      By ClaudioG in forum Australia, New Zealand Club house
      Last Post: 04-27-2008, 01:43 AM
    3. Just started building a small CNC
      By razzledog in forum Australia, New Zealand Club house
      Last Post: 03-03-2008, 12:46 AM
    4. Started building at last!
      By The Wizard in forum CNC Wood Router Project Log
      Last Post: 09-05-2007, 04:16 AM
