Results 1 to 7 of 7
Thread: Ultimate 4x4 hybrid?
    Nov 2007
    So, I plan to buy a set of plans and build a 4x4 with tax return money, (unless the govt. bounces me a check, lol)
    I'm sure a lot of this is covered in the private forum, but, what bells and whistles or cool options/upgrades, etc. would you add to the basic build keeping in mind that it will be a semi production machine?
    I use a small moosecreeksales machine that i tuned to do small carvings on cabinet doors, etc, for built ins that my company builds. The 4x4 is the next budget conscious step up for me.
    Thanks!!
    Darren
    Gold Member lovebugjunkie's Avatar
    Apr 2005
    Add a "auto tool zero setter for the Z"
    Another Aussie Auto Tool Zero Setter
    Makes setting the Z quick, easy, and the same every time.
    Also the xbox360 controller on the Mach3 forum is an cheap and easy way to jog your machine around and a few other functions.
    Nov 2007
    thanks for the link. Lots of info there.
    Man, over 100 views and 1 response...I was hoping for more.
    I'm leaning very seriously towards the bladerunnersupermax4 combo...any one have any pros or cons to share?
    www.joescnc.com joecnc2006's Avatar
    Aug 2004
    Steel frame, Steel support bed, But would require welding, I tried to design a machine for the "Average Joe" to build.
    Also Aluminum carriages.
    Joe
    Nov 2007
    Welding a steel table and top would be no problem, but I was really drawn to
    Chris's torsion box cabinet and top. Do you think that type of construction would work as well?
    Aug 2004
    Quote Originally Posted by darren salyer View Post
    Yes, a good wooden Base will work just as good as long as you have some sort of climate control. and as always with many machines any variances which can occur you can re machine the top for corrections. I resurfaced mine a total of three times onver a one year period, you can always add more MDF Glued to the existing and surface on top of that down the road. Mind you one of my resurfaces was when I moved and reassembled the machine.
    Joe
    Nov 2008
    We are still waiting for you to figure out which bit and feed rate to use to machine the 3/4" aluminum plate to make the aluminum carriages!
    1. How would you build your Ultimate CNC
      By jeepster0000 in forum Bridgeport and Hardinge Mills
      Last Post: 10-01-2007, 09:41 PM
    2. the ultimate use for cnc
      By fishmonster13 in forum Machine Created Art
      Last Post: 08-22-2007, 03:00 PM
    3. the ultimate S1 cnc.....
      By gus in forum Bridgeport and Hardinge Mills
      Last Post: 02-27-2007, 08:22 PM
    4. The ultimate cnc machine
      By Cold Fusion in forum CNCzone Club House
      Last Post: 01-06-2004, 12:16 PM
