Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Joes CNC Model 2006
Old 11-11-2008, 10:00 PM
soundwaves is on a distinguished road
circle cutting
Im new to this and think the hybrid 4x4 is for me. What I would use it for would be 3/4"MDF templates, circles, ellipses, etc.. I use these a lot in my industry. My question is this, once you cut a circle free of the main work piece, does the circle stay put or do you have to hold it as the router finishes its pass. When I use my hand held circle/router cutter, you have to be very careful to finish the circle so it does not get near the cutter and flop around. Also, you have to clean up the little point it leaves behind. Can I get perfect pieces every time without cleaning up the edges, can I leave it unattended to cut multiple pieces and guaranty that it wont damage the piece and bit? And last but not least, to maximize material use, can I cut multiple circles within each other, 2" 4" 6"...... Thanks for all your help and look to be cutting soon!!
Oh yea, could I engrave Aluminum on this machine? What about cut through it, what would be the maximum thickness??
Old 11-11-2008, 10:11 PM
Sinkoumn's Avatar
Sinkoumn is on a distinguished road
Just program tabs into your G-code and you're set. If you're mass producing a LOT of them, trimming the tabs may be a little bit of a hassle, but just get a laminate trimmer or a table router and use a flush cutting router bit to take off the small tabs that hold the circles/ellipse/etc in place on the CNC table.
www.NeustonBoards.com
Mike
Old 11-11-2008, 11:23 PM
thats genius! a laminate trimmer will be perfect to finish them off.
Old 11-12-2008, 09:16 AM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
Joe
Old 11-12-2008, 09:34 AM
Sinkoumn's Avatar
Are you going to be making a lot of subwoofer and speaker boxes? If so, and you're fiber-glassing them you might not even have to trim all the tabs since many of them will be inside and completely out of sight once the canvas is stretched over the wood frame and glassed.
Mike
Old 11-12-2008, 11:46 PM
Yea well be making lots of glass style enclosures so the tabs wont be a problem. What I want to branch out the cnc for is selling custom made templates. Perfect ellipses that pocket into one another are to die for, Ive been wanting these for a while and as it stands now, we make forward and reverse pieces by hand and thats very time consuming.
Need Help!- Circle cutting still have kinks after backlash adjustment. alexccmeister Benchtop Machines 2 09-21-2008 08:38 AM
Circle not cutting completly hduke47 Laser Engraving & Cutting Machines 1 02-18-2008 02:36 PM
Problem cutting a round circle Sandor_nl Laser Engraving & Cutting Machines 3 02-14-2008 07:43 AM
cutting curves, circle, radius? _taz_ Benchtop Machines 2 02-08-2008 11:57 AM
circle cutting wizard problem kb7vms Mach Wizards, Macros, & Addons 7 11-05-2006 11:14 PM
