Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Joes CNC Model 2006
Old 08-30-2008, 12:14 AM
mike hide is on a distinguished road
advice on longer wires
I need to rewire my machine .Initially I was considering a mobile workstation but realized all I needed in the proximity or the work was the monitor and a mouse.
So I am going to make an enclosure for the computer and hobby box of tricks . this unit will go under the machine ,out of the way .the machine is roughly 4'by8'. This will involve one wire run in the region of 16'.
The original Hobby kit wires are not nearly long enough. So I am asking those of you that are electrical savvy what kind of gauge should the wires be, what is this type of wireing called and who is a good supplier any help appreciated regards mike hide
Old 08-30-2008, 11:50 AM
calgrdnr is on a distinguished road
Hello Mike
I used cable real similar to this http://www.grainger.com/Grainger/items/1YPT6
I got mine at a local electronc supply ( ask for antenna rotor cable )
My x axis motor control cable is at least 16ft maybe 18 I was a bit concerned it might be to long, but so far no problems.
Good luck Kent
Old 09-07-2008, 03:50 PM
*Registered*
ZigMan is on a distinguished road
I got mine at Fry's and the price was great. Just make sure you get the shielded cable and ground the shield to the common wire.
Old 09-07-2008, 04:38 PM
Originally Posted by calgrdnr View Post
Hello Mike
Good luck Kent
I tried the local Grainger but they will only sell it by the spool,$360 .thanks for the help .I did get a local Quote from Greybar electric 50' for $75..if allelse fails I will buy from them .
Old 09-07-2008, 04:41 PM
[QUOTE=ZigMan;498268]I got mine at Fry's and the price was great. Just make sure you get the shielded cable and ground the shield to the common wire.[/QUOT
awill trey them tomorrow ..thanks .mike hide
Old 09-08-2008, 07:49 AM
jvanick is on a distinguished road
Is the shielding critical ?
Just curious because I'm getting ready to wire up my jgro.
-J
Old 09-08-2008, 09:51 AM
I believe it is preferred, Mine is not shielded.
I have not had any issues yet.
I could not find shielded, they were out and I was in a hurry J
drill rod longer than 36"? where? CNC Darren DIY-CNC Router Table Machines 3 09-25-2004 08:17 PM
New longer Y CNCadmin Benchtop Machines 5 08-12-2004 06:40 AM
adding a longer bed balsaman Mini Lathe 13 04-09-2004 09:31 PM
Longer Lathe Bed boyd32450 Benchtop Machines 6 02-19-2004 01:17 PM
