I'm starting a 4x4 build and I'm going all out 3 1/4 porter, with gecko 203s and 570 motors. But I've run into an issue what PSU should I use for those drivers and motors? Is this one big enough http://www.antekinc.com/PS-5N70R.pdf or should I go with http://www.antekinc.com/PS-15D70R.pdf Or maybe something on this page. http://www.kelinginc.net/SwitchingPowerSupply.html I'm eyeing this one KL- 7220 Specification: $189/pcs Unregulated Power Supply 1440W, 72VDC/20A ,120VAC or 230VAC This is the one area I'm not really sure about. I'm not really too worried about the price just want to make sure I have enough power and a little head room. Last edited by Don Kellogg; 08-21-2008 at 02:13 PM. |
| If you wire the motors parallel, you want a 48Volt supply, and about 4 amps per motor will give you a little headroom. Parallel will give the best performance.
| Jerry & CR are right!!! Here are the calculations so you can verify your assumptions. Current: 5A x 4 motors=20A x .67% =13.4A Vmax(Motor)=(SQ RT of Inductance) x 32=1.516 x 32= 48.53Vmax. In some cases the Pwr Supply Capacitors may not be sufficient for your application. so check total Cap, against this formula. Capacitor Selection:C=(80000. x 13.4A)/48.53V = 22089uF Good luck....W.Smith Last edited by CNCfun&games; 08-22-2008 at 09:46 AM. Reason: Incorrect formula |
| I should have mentioned that, (Because steppers at rest are drawing current and this lowers the output voltage somewhat.) with three or four motors connected--NO individual motor will receive more than 48V from the 50V power supply. CR. |
6.8mH inductance |
#10
| Yep, that's correct. If I recall correctly, the motors Probotix sells have rather high inductance. This is because they are low current motors to work with their lower current drives. The best performing motors have high current and low inductance.
#11
| Would like to use the Gecko 203 drivers and have a 48VDC 15amp P/S. Any recommendations on motors ? |
#12
| You haven't said anything about how you are going to drive the axes so this could change but generally you can probably use a G540 controller, 270 oz N23 motors for X and Y, a 387 oz motor for Z and a 48V 7.3A power supply. $299 G540 http://kelinginc.net/GeckorDriver.html $078 Two $39 KL23H276-28-4B 270 oz motors for X & Y $049 One KL23H284-35-4B 387 oz motor for Z $060 One KL-350-48 48V/7.3A power supply. $010 Estop switch $007 3 Home switches $009 Straight thru parallel computer cable. ----- $502 Total electronics cost. $149 Mach3 cost with above purchase. $651 To spend at Keling. http://kelinginc.net/ This most likely will be the best electronics for your router. Start by reading this: http://www.cnczone.com/forums/showthread.php?t=76865.#3 CR. |
| Need Help!- WTF C11G Gecko 203V | georgeburns | DIY-CNC Router Table Machines | 17 | 06-05-2008 10:57 AM |
| pac-sci and gecko 203v | JKuhn | Gecko Drives | 0 | 10-06-2007 11:42 PM |
| gecko 203v question | skankpile | Gecko Drives | 2 | 09-25-2007 04:41 PM |
| Gecko 203V or MCP's MSD556 ? | Argofanatic | Stepper Motors and Drives | 110 | 02-05-2007 02:38 PM |
| Gecko 201, 202, 203V vs WS-2H090M | Goose80 | Gecko Drives | 2 | 01-20-2007 01:14 PM |
