I was researching and pricing out plastics when I came across a product called Boatboard a.k.a. Starboard (a modified HDPE for marine use) that looks really promising. A 13" x 13" x 0.5" sheet costs only $10 and it's available in 5 different colors. Even a one inch block of that size costs a mere $17. One downside is that it "has a slightly textured no slip, anti-marking surface". Provided that the texture is just a surface finish (ie: not formed by deliberately introducing microscopic bubbles while forming the HDPE sheet), it shouldn't pose too big of an issue for us. Here is where I found it: http://www.polyzone.com/asp/Product.asp?PG=2189 Has anybody used this stuff before? Is it just as wear resistant and slippery as regular HDPE? Is there an even cheaper source for HDPE out there? |
| Did you Google Boatboard? I thinkl it is just a marketing ploy aimed at boat owners. They call it a modified HDPE and I think the modification is the textured surface. The properties claimed are just standard for HDPE: doesn't rot, yes correct, doesn't delaminate, yes correct etc. And $10 for 13" by 13" at 0.5" thick is about $9.50 a square foot; is that much different to standard HDPE?
| From the same site, a 12" x 12" x 0.5" sheet of HDPE (natural) costs $37.50. Joe uses it, so that's pretty much a slam-dunk endorsement in my books. ![]() I found a Canadian site that carries the same stuff under the tradename of Starboard: http://www.theplasticstore.com/default.asp |
| Yes - I used it for the "cars" on my System2. (see User's Photogalery) Starboard -- Cuts well - machines easy - you'll need to work stepover to get the finish right. Doesn't adsorb moisture - I've found it stable in "shop" conditions. Can't say if its "just" repackaged to target boaties -- but the price you found is probably 1/2 to 1/3 what you'd pay a marine supplier! There is a special 3M (I recall) adhesive. It will Drill and Tap - but if using as a drive for threaded rod -- you'll have some backlash! Jim
__________________ Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it. |
| "low end" HF Spindle or "high end" router for about $1000? | biomed_eng | DIY-CNC Router Table Machines | 14 | 01-06-2012 12:15 AM |
| BattleAxe "aka" Ball and Chain "aka" the wife. | ZipSnipe | CNCzone Club House | 48 | 05-18-2008 09:53 AM |
| G320 "common" or "+5vdc" why do they vary? | beezerlm | Gecko Drives | 3 | 01-12-2008 04:00 PM |
| Vertical system "jerks" and "bangs"?? | REVCAM_Bob | Servo Motors and Drives | 5 | 06-12-2006 09:09 AM |
| Add "View New Posts" to "Main Menu" | Mr.Chips | Forum Questions or Problems | 4 | 04-21-2004 10:54 PM |
