A friend of mine is cutting the bearing slide assemblies for me and there are no hole dimensions in the PDF. From the downloaded Edrawing I'm showing 0.344" for the X-axis bearing slides that use the 5/16" bolts. That gives a fair amount of slop considering the bolt is about 0.304". Is that desirable in order to align the machine on the rails? That is the only reason I can think of for that amount of wiggle. |
| The alignement comes from the fit of the angle in the grooves. The extra wiggle room allows you to be off a little on the hole location in the aluminum verses the MDF and allows for the difference in expansion due to temp. |
| My X-axis table is nut-on. I skinned it yesterday and this thing is starting to look like a machine. |
| Npt thread milling pre hole sizes | magneto259 | General Metalwork Discussion | 2 | 04-12-2007 06:33 AM |
| Found a strange slide-assembly | dar303 | Linear and Rotary Motion | 3 | 10-29-2006 02:45 AM |
| Need a source for this bearing mount/assembly | SteveL | Linear and Rotary Motion | 2 | 09-17-2006 07:43 PM |
| THK slide bearing | Bill Davis | Mechanical Calculations/Engineering Design | 2 | 08-26-2006 06:31 PM |
| Screw, Bearing, Motor assembly (Nook) | Ziggster | Linear and Rotary Motion | 5 | 03-14-2006 08:28 PM |
