Page 2 of 2 FirstFirst 12
Results 13 to 17 of 17
Thread: 1/2 8 2-start vs. 1/2 10 5-start
  1. #13
    Nov 2004
    To give you a little more encouragement I used the 5 start screw on my Joe 2006 unit for the X axis and I love it... It moves so smooth and FAST! You won't be disappointed.. I am using the Kelings 450oz steppers on mine.
    Bob W.
  2. #14
    Sep 2007
    I believe dumstercnc.com has nuts for 5 start. He is a nice guy. Check with him and see if he ships international.
  3. #15
    Registered Check twice!'s Avatar
    Jan 2008
    Bob
    Bobf
    I did send a message and will see what comes back. Your site led me to this url to follow. http://www.techno-isel.com/lmc/Produ...ID=13262911021
    But they do have alot of the gear needed.
    John
  4. #16
    Jan 2008
    Techo only has 1/2" 10 start rod. I have not heard this being used in any builds. Their quote seems low for the rod.
    Can the 10 start be used and does it create other problems I may not be aware of.
    The type of lead screws could someone enlighten me on a piticular type a link would be great.
    John
  • #17
    Mar 2003
    Shelby Twp, MI....USA
    Quote Originally Posted by Check twice! View Post
    10 start is usually 1 turn per inch. So it'll move twice as fast as 5 start. But, it'll need twice the torque to provide the same cutting force. If you gear it 2:1, you'll get the same effect as using 5 start.
    Basically, as the lead increases (turns per inch decreases), you're speed will increase, and the force provided by the screw will decrease. When using steppers, the force does not necessarily decrease proportionally to the speed increase, due to the fact that steppers have more torque the slower they spin. It's very possible to actually not lose any force while doubling top speed.
  • Page 2 of 2 FirstFirst 12
    1. I don't know where to start...
      By Fluxion in forum Mach Wizards, Macros, & Addons
      Last Post: 09-11-2007, 12:40 PM
    2. Where do I start looking?
      By IYWD in forum DynaCNC
      Last Post: 07-02-2007, 06:40 PM
    3. Single start vs double start ballscrew.
      By darik in forum Linear and Rotary Motion
      Last Post: 03-21-2007, 08:53 PM
    4. Where to start
      By bearwen in forum Open Source CNC Machine Designs
      Last Post: 02-14-2006, 11:57 AM
    5. Start!
      By CharlieM in forum Kellyware CAM
      Last Post: 05-07-2005, 06:57 PM
