Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Joes CNC Model 2006
Old 03-09-2008, 09:25 AM
BobF is on a distinguished road
How to ? Headboard
I need to cut a headboard for a bed I am building. The headboard is about 22" wide and a little over 60" long. To do this on my Joes 2006, I will have to cut one end and relocate the stock, and cut the other.
I have drawn 1/2 of the shape and I will mirror it to make the other side in Vcarve. Currently I have an alignment strip along the long axis and that will line up one edge of the stock. I am thinking about installing a pin I can use to locate the length. I will need a small hole in the back of the headboard to locate the stock, especially for the second cut.
Has anyone done this? What was the result?
Anyone have a better idea?
Anyone have experience and can share the "gotyas"?
Old 03-09-2008, 09:37 AM
Moderator
bp092 is on a distinguished road
What kind of material are you cutting? I wouldn't on a joe 06, more work than it's worth. I would however cut templates on the 06. I'm assuming it's a curve, if you're carving the headboard I would make a jig, carve out 2 parallel lines in your spoil board, make inserts for them so you can slide it, rip the glueup/mdf to fit snug in there. Or you can use locator pins, 1/4" dowels into your spoil board and plan it out in your vcarve. Either way you will get it very close with careful setup. I would test it in MDF first though if you aren't using MDF and make sure the program and setup works. But like I said if it's just a curved cutout or detailed I would do it by hand with mdf templates cut on the 06. You could even make them in two parts, transfer it to a larger template stock if needed. If there is a profile on it I would do it by hand with a router, but usually people do applied moldings.
Old 03-09-2008, 09:45 AM
rdhharm is on a distinguished road
Bob,
Can you post the V-Carve file I have an idea but I would like to see it first before I give a suggestion
Rick
Old 03-09-2008, 09:50 AM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
ya, a v-carve file would help and we can see the easiest way to do it.
joe
Old 03-09-2008, 09:55 AM
I will post it later today, its on the other computer. I am thinking I will make 2 paths, one for the shape I have drawn, and a second for the mirror of the shape.
Old 03-09-2008, 10:00 AM
joecnc2006's Avatar
www.joescnc.com
yes, all you need to do is mark the mate point and slide material to that point.
joe
Old 03-09-2008, 10:16 AM
There should be a zipped crv attached that has the profile of the headboard.
This just shows half the headboard and the vertical line represents the center. I will have to mirror the left side to the right to make the complete headboard. I may also add some carving in the middle.
Old 03-09-2008, 10:29 AM
I would do as Joe pointed out do half and make a reference point and do the other half
As for the carving I would do it with a different V-Carve file with the starting point on the center of the material.
Rick
Old 03-09-2008, 04:01 PM
Bertram is on a distinguished road
Originally Posted by BobF View Post
... Currently I have an alignment strip along the long axis and that will line up one edge of the stock...
Assuming you are just cutting out the shape (and no carving in the middle), I would add an alignment strip along the short axis also. Cut the 1st half and then simply flip the material end for end and cut the 2nd half. The material will have to be the finished width to begin with, or have the same amount of overhang at each end.
Old 03-09-2008, 06:56 PM
Yes that could be done but Bob would have to make half of the shape in a mirror image upside down tough to make that perfectly aligned.
Rick
  #11   Ban this user!
Old 03-09-2008, 07:13 PM
Originally Posted by rdhharm View Post
Yes that could be done but Bob would have to make a mirror image of the shape upside down tough to make that perfectly aligned.
Rick
Not at all. I mean FLIP it end for end, not rotate it. Essentially using the same cut but from the other side of the material. Admittedly it will only work if any holes are through holes, and there is nothing else cut but the profile.
  #12   Ban this user!
Old 03-09-2008, 07:26 PM
I am sorry but that will not work if you FILP it it will be cutting on the bottom of the first cut not the top. Or you could like you said cut from the back side that will work if there is not a detail on the cut like a using a 45 degree bit
Rick
