Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Joes CNC Model 2006
Old 03-04-2008, 04:04 PM
lookout4lpe is on a distinguished road
A New Mod 2006
Joe,
Thanks to you and the entire community, I have just completed a very satisfying project. A few final items and I'll be ready for startup. After much Zone reading and other sources, I was able to miss most of the problems and add the ideas of many to improve on the design and a create machine that I am really looking forward to using. The pictures show my product with limit and home switches to be added and the computer to be attached in a couple of days. I'll post my first cut soon.
Len
ID:	54804   Click image for larger version
ID:	54805   Click image for larger version
ID:	54806   Click image for larger version
Old 03-04-2008, 04:14 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
fantastic job on the machine, and all in one self contained system.
joe
Old 03-04-2008, 08:41 PM
timberwood is on a distinguished road
Fantastic!
Len,
Fantastic build! Looks like lots of attention to detail. Did you make it out of aluminum?
Daryl
Old 03-05-2008, 03:39 AM
Daryl,
The detail is in the design, very well thought out. No, aluminum is not my medium. Like you, I am a woodworker that needed a cnc router in my shop.
Len
Old 03-05-2008, 08:02 AM
I see. Did you use mdf, baltic birch or some other multi-ply product? I like mdf for its machineability, paintability and dimensional stability, but don't like the way it fragments, its limited structural strength and cannot take too much wear and tear. I'm thinking of using a multiply product just to maybe have it last a little longer. Should I worry about that?
Also, I'm wondering about a little thing like time and expense vs. return on investment. I design and build custom homes and like to use my woodworking skills to build the custom stuff that goes into a large custom home, in addition to building furniture when I have time. So, I'm trying to understand what this machine can reasonably do to help in many areas, one of which would be to save me some time.
So, how does it work for:
  • Mortise and tenon
  • Profiles like molding
  • Dados
I have never had the opportunity to see a decent CNC router work in anything but making signs. My local millwork supplier has a huge CNC unit and all I've seen them do is make signs.
Daryl
Old 03-05-2008, 10:27 AM
zachjowi is on a distinguished road
nice machine and nice pile of lumber.
Old 03-05-2008, 02:27 PM
Daryl,
I did use mdf and agree with you on its strong points. I have not experienced too much fragmentation and don't believe I have used any mdf jig or fixture to failure. I would have to defer to others that have mdf routers to comment on long term use in your type of business.
As for mortise and tenon, molding, and dados, I would stick to the traditional methods. A table saw, a hefty molding machine, and square chisel mortising machine can't be replaced by a cnc router. I see the cnc router for signs, cabinet door panel decoration, carving and that type of work. I appreciate your concern about saving time and return on investment. I hope you can figure out a balance that works for you.
Len
Old 03-05-2008, 02:36 PM
Zachjowi
My home is in the center of 150 acres of oak, pine, walnut, and poplar. I cut what I need, put it through my sawmill, airdry, get to 7% mositure in a kiln, and then into my shop for cabinets, furniture,and fun projects.
Len
Old 03-05-2008, 04:22 PM
Moderator
bp092 is on a distinguished road
Wow you're lucky! Nice stock pile, great machine.
4 x 8 2006 Joe, Anyone? deanbrock Joes CNC Model 2006 5 01-08-2008 04:11 PM
My Joe 2006 Router xscsime Joes CNC Model 2006 20 01-21-2007 09:26 PM
2006 jybute GibbsCAM 0 09-26-2006 12:45 PM
Feature Cam 2006 sundy58 FeatureCAM CAD/CAM 0 08-28-2006 09:50 AM
