Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Joes CNC Model 2006
Old 01-21-2008, 11:34 AM
bradtal is on a distinguished road
Neat way of creating the bearing slides...
Hello All-
I was building my bearing slide assemblies this weekend and used an interesting way to get all the bearings in the correct locations.
In the past, when I made the bearing slide assemblies for my previous cnc machine, I just measured the locations where the bearing assemblies needed to go. This worked ok, but some of the bearing assemblies were located "just off" where they needed to be.
So, this time, I used a different method. I will try and explain with the pictures below...
Image 1 - Mark the horizontal locations where the bearing assemblies will be on your aluminum angle.
Image 2 - Using another piece of scrap aluminum angle, position it behind and above the marked aluminum angle. Place a bearing you will be using on the marked aluminum angle and up against the "fence-piece" of scrap angle over one of the marks you made.
Image 3 - Use a "brad-point" drill bit the same diameter as the inside diameter of the bearing.
Image 4 - Slide the bearing back and forth a bit keeping pressure against the back scrap aluminum fence. Push down on the drill bit enough to "mark" the aluminum. Because the bearing is rolling against the back fence, it will create a perfectly horizontal line.
Image 5 - The location is now marked. I then took this to the drill press and used the same brad-point bit to drill the hole. Yes, you still have to be pretty precise to line up the tip of the bit with the intersecting lines, but I found this to me more accurate than just measuring with a ruler/scale.
Image 6 - The finished bearing slide assembly. It sits perfectly flush with the linear pipe and slides like a dream.
Hope this helps.
Brad
ID:	51336   Click image for larger version
ID:	51337   Click image for larger version
Old 01-21-2008, 01:17 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
I just use a template and center punch, the bit in the drill press will put the bit spot on.
then mark the stepdown and use tablesaw to clear out the material, Using a srap wood at a 45deg. to rest aluminum angle against. leaves a clean and smooth finish.
ALWAYS WEAR SAFETY GOGGLES.
Joe
Old 01-22-2008, 07:47 AM
PhillyCyberJoe is on a distinguished road
Great idea, Bradtal!! I wish I thought of this when making mine. On a couple, I had to adjust by elongating the hole so that the bearing would ride on the pipes.
Thanks...
Old 01-22-2008, 10:46 AM
anoel's Avatar
anoel is on a distinguished road
You know a simple fence clamped to your drill press table will do the alignment thing brilliantly too.... Add a couple of stop blocks to your fence and you can get perfect spacing every time too...
Nathan
Old 01-24-2008, 10:52 PM
Sbthomas13's Avatar
Sbthomas13 is on a distinguished road
Bradtal-
My friend Tyler and I followed your method exactly when drilling our bearing slides for our Sophomore Build machine. It worked perfectly and was really easy!! I definitely recommend this procedure to anyone who is trying to make the bearings.
Old 01-25-2008, 04:39 PM
Originally Posted by Sbthomas13 View Post
Bradtal-
Sbthomas-
Thanks for the feedback! I am really glad you were able to follow the procedure and it worked for you. That was the reason I shared it. Not everyone has a fence on their drill press, templates, etc. The method I showed I was hoping would help others, so thanks for letting me know!
PS. I have been following your's and Tyler's "Sophomore Build" post. You guys are doing a great job and it has been one of my favorite threads to read. Keep up the great work and make sure you keep us all informed on the project, even after completion!
Brad
Deskengrave- Neat Program!!! Russ Shugg Carken Products (Deskam, DeskCNC etc) 6 03-29-2012 09:29 AM
Neat sterlings Brass_Machine Stirling Engines 4 08-20-2007 08:09 AM
Neat cutting oil on Hardinge? rpseguin General Metalwork Discussion 0 07-04-2007 05:07 PM
Linear Slides v/s rail slides bryanrabb DIY-CNC Router Table Machines 4 03-27-2006 08:45 PM
neat looking mini mill mark c Benchtop Machines 7 09-28-2004 02:29 AM
