Hi there. I am currently building a modified version of joe´s machine and have been playing aroung with the idea of using a rotating nut setup for the x and y axis. So i was hoping someone could tell me what gearing ratio would be suitable. The lead screws are 12mm x 3mm pitch (in us around 1\2"-8tpi). And i will be using a 425oz\in kit from xylotex. I don´t know what i am to expect in terms of speed and torque. But i was hoping to cut at minimum 60 ipm. Mostly guitar building and signs Thanks. |
| thanks for youre quick response joe. And thanks for youre great work on the plans. Of course youre right on that one. But i was actually considering gearing the rotating nut up. Because i see a lot of you guys are using higher pitched leadscrews like 4tpi or higher. and as i understand the 425oz\in motors would loose a lot of strength at the higher rpm´s needed to get the same speeds from a 8tpi leadscrew. So by gearing the nut up and keeping the motor rpm´s down using timing belts and pulleys i am assuming i should be able to get what ever (tpi) i want. So i was hoping someone could tell me what gearing ratio would be suitable ![]() (The sweet spot). if there is such a thing Hope you see what i mean. My english was never that good |
| "low end" HF Spindle or "high end" router for about $1000? | biomed_eng | DIY-CNC Router Table Machines | 14 | 01-06-2012 12:15 AM |
| BattleAxe "aka" Ball and Chain "aka" the wife. | ZipSnipe | CNCzone Club House | 48 | 05-18-2008 09:53 AM |
| G320 "common" or "+5vdc" why do they vary? | beezerlm | Gecko Drives | 3 | 01-12-2008 04:00 PM |
| Has anyone looked at the "JET" or "Shop Fox" manual machines? | boosted | General Metal Working Machines | 12 | 03-04-2007 09:33 PM |
| Vertical system "jerks" and "bangs"?? | REVCAM_Bob | Servo Motors and Drives | 5 | 06-12-2006 09:09 AM |
